C450/C43 AMG
When to engage in Sports Mode
Old Mar 31, 2020 | 07:39 PM
AMG C43 3LV6's Avatar
AMG C43 3LV6
Hope everyone is keeping safe given the pandemic, esp to my USA brothers. Im in Australia.
2018 C43 Coupe (March 2018 purchase)
Anyways, I know you are meant to only engage Sports+ when the temp of the oil and engine is white (ie not blue)
When can you engage in Sports mode and what is the max RPM that you should be pushing when the temps are still blue. Thanks.
Old Mar 31, 2020 | 07:59 PM
imj0257's Avatar
C450 AMG
I drive in Sports+ all day every day, unless my wife is in the car and then I drive in Comfort.
Old Mar 31, 2020 | 10:03 PM
jonathan358's Avatar
2018 Mercedes C43 AMG Coupe
Same...
You can switch to any mode as long as you aren't loading the engine too much -- regardless of temperature. Changing modes just changes the throttle response.
If I want to warm up trans fluid faster I may switch around 40*C and keep under 3.5k rpm.
Old Apr 1, 2020 | 01:15 AM
zibby43's Avatar
'20 GLC300 SUV
Originally Posted by jonathan358
Same...
This is a great tip. I do the same.
Transmission fluid takes a long time to warm up in this platform. Putting the car in Sport after ignition and driving in this mode is a great way to help the transmission get up to temperature faster without thrashing it.
To the OP - as the other posts mentioned, you don't have to wait to engage another drive mode. It's all about the load and how much you're winding it out. Just keep the revs under control until both the oil and transmission are at normal operating temperatures.
Old Apr 1, 2020 | 09:12 AM
AMGiggity's Avatar
nothing
Same...
changing the mode also changes the transmission characteristics not just throttle response
Old Apr 4, 2020 | 11:53 AM
shaungrey's Avatar
C43
I don’t believe there is an official and correct answer. Personally, I keep it in comfort until engine oil is 40 Celsius and then to sport. I don’t use full load or rpm until oil temp is up to normal range. I’m in Canada so half the year the transmission oil rarely gets to normal operating temp on an 18km drive. Seems to torque manage a bit if I’m in sport plus and transmission temp not fully up to temperature.
Old Apr 4, 2020 | 07:06 PM
Darrington's Avatar
2015 C400
Start car, sport mode. Every day. Well, except recently, since I haven’t left the house in 3 weeks!
Old Apr 5, 2020 | 11:58 AM
18bora's Avatar
2020 GLC 63
I normally,
1- Turn on the ignition.
2- S+ mode before starting.
3- ???
4- Profit !!!
Old Apr 6, 2020 | 07:16 AM
HighSun_Murder's Avatar
C43 AMG / C350 Coupe
Sport+ mode all day / every day is a good way to spend an extra $400+ per month on gas lolz. I cruise in Comfort mode then switch to S+ when I feel the need to "get on it".
Old Apr 6, 2020 | 11:36 AM
batman719's Avatar
2019 C43 AMG Coupe
+1. You're also teaching the vehicle to drive like a nanny in S+ when you're in S+ all day / every day.
Old Apr 6, 2020 | 01:20 PM
I noticed a difference in performance by disabling traction control, seems the transmission is not AS confused with it off.
Old Apr 6, 2020 | 01:33 PM
