S205 Wagon Lowering/Spacers
Just looking for confirmation if anyone has used the H&R 28811-2 springs with 12/15mm spacers on a C43 S205 wagon?
I just want to make sure they work properly as some sites say they are made for the wagons and others say sedan only.
Thanks!
Also I have seen that the saloon HR springs settle a litte lower at the rear than the wagon specific ones do?
Any more info would be appreciated as I'm planning on changing my alloys and suspension to get the look I would like, But I also want the original wheels to be available to me once lowered.
Any advice you could all offer would be appreciated.
Stock set-up
[img]file:///C:/Users/darin/AppData/Local/Temp/msohtmlclip1/01/clip_image001.jpg[/img]
Stock set-up
I'm running 20" with lower profile tires and H&R springs. If you want 20" rims, you're looking at aftermarket in which case, you won't need spacers if you get proper offsets.
excited to get her looking how i like it. don’t pick the car up until friday but i need to be on top of things.
cheers guys. i’ll be spending a bit of time on here from now on.
https://mbworld.org/forums/c450-c43-...ent-guide.html
As far as springs, I don’t have any experience with Eibach, but have used H&R on my last 3 cars. IMO, perfect ride height and great performance. Can’t go wrong with H&R.
do you or anyone for that matter know whether my 2017 s205 is the same as your 2020. i don’t want to use your set up as a guide only to find i have issues due to a different model year.
wheel choice on these seems much harder than any cat i’ve previously owned imo.
cheers
cheers
they are 8.5/9.5 et 45/47. so i believe i’ll need a 15mm spacer on the front & only around 5 on the rear. i plan to lower with H & R also.
mid somebody could please let me know if this is good to go i’d be very grateful. thanks
