C450/C43 AMG
2020 C43 w/ JB4 + BCM
Old 08-31-2020, 04:02 PM
1Gunner's Avatar
2020 C43 sedan(hers), 2021 Porsche 992 TurboS(his)
My first couple of tries.
Old 08-31-2020, 04:08 PM
1Gunner's Avatar
My 1/4 mile times sucked.... need to hold the throttle open longer!!
Old 08-31-2020, 04:14 PM
Diirek's Avatar
2020 C43 AMG Coupe
Makes me that much more excited to get mine!
Old 08-31-2020, 04:52 PM
RichardCranium3's Avatar
'19 CLS450
Great validation for the FL community here that's on the fence...BMS or bust!
gabemcclintock's Avatar
2019 C43 AMG
That is impressive. BCM installed as well?
Old 08-31-2020, 05:04 PM
1Gunner's Avatar
Yes, just as the thread title says!
Old 08-31-2020, 05:15 PM
2019 C43 AMG
🤦‍♂️ maybe I should read. LOL
Can I ask what numbers for you have for your Duty Bias?
Old 08-31-2020, 05:39 PM
c43PDX's Avatar
C43 AMG
any supporting mods, tires and which map? I have mine, just need to get installing..
Old 08-31-2020, 06:24 PM
1Gunner's Avatar
Not sure what you are asking re: numbers for Duty Bias??
100% stock with the exception of Michelin PS4S tires instead of the crappy run-flats it came on.
full tank of 94 octane on map 3.
Old 08-31-2020, 07:00 PM
2019 C43 AMG
Then I assume you're at the default numbers.
Old 09-01-2020, 09:52 AM
Howyalivin's Avatar
Acura TL-SH, among others
Great times! I'm glad to see that you went with the BCM. Your car is definitely an 11's car, on pump gas, with just a JB4. I think that puts to rest any thoughts the 2020's can't make equivalent power to the PFLs. Having said that, 12,7 @76mph? Yeah, I'd say you definitely let off. You need to find a place where you can stay in it the whole run.
Old 09-01-2020, 11:11 AM
1Gunner's Avatar
It definitely rocks the 0-60! Times are quicker than my GT3 Touring.. 4.06 best, but my manual shifting needs practice!
1/4 mile runs feel flat on the top end, not pulling about 3/4 way through which is why I had lifted.
This time was slightly better, still let off as seen by the 86mph trap spd...... Will try again and this time hold the damn throttle!! LOL
Old 09-01-2020, 12:36 PM
Howyalivin's Avatar
The 43's do run out of pull up top, because of the size of the turbos, which is why the mile per hour is normally lower than you would expect for the times that some guys are running. As for shifting, the best times that I've heard of guys running were always in auto w/ the suspension set to comfort vs. sport, to help weight transfer off the line. While you're in practice mode, give both ways a shot. Presuming everything is running well, I would think you should be running 115+ mph
1Gunner (09-01-2020)
Old 09-01-2020, 03:28 PM
Ramsino's Avatar
C43
I'm not sure I understand. Are you saying that comfort suspension is better for straight line launches because there is more flex?
Old 09-01-2020, 03:41 PM
TWINTURBOS's Avatar
2016 c450
Wow, that's very nice. I thought you were running e85. The latest gen c43s seem to be very impressive in terms of acceleration.
Old 09-01-2020, 04:09 PM
'19 CLS450
Yes - allows the weight to transfer a bit more aggressively to the rear on a dig
Old 09-01-2020, 04:22 PM
Ramsino's Avatar
C43
I understand this in theory, but does the suspension setting actually do enough for the result of this to be measurable? I mainly have my rear tires about 2psi under my front for this reason, but I didn't think the suspension stiffness from Comfort to Sport+ would actually help.
Old 09-01-2020, 04:43 PM
Howyalivin's Avatar
It does make a difference. It has been proven by several of the fastest cars on the board. In most cases, a one tenth difference in 60 ft. time is equal to 2 tenths in your quarter mile time, so even small benefits count. Consider, that means that .05 second difference in the first 4 car lengths translates to one tenth off of your quarter mile time. In Sport+, the suspension is stiffer, better for handling, but worse for a launch from a dead stop.
Old 09-01-2020, 04:58 PM
Ramsino's Avatar
C43
Very interesting. I will have to try this.
Old 09-01-2020, 05:54 PM
1Gunner's Avatar
Had it set on S+ & sport + suspension. Will try comfort setting next time also! I did have traction turned off and didn't feel any wheel spin.
I also brake boosted the launch to 2000 RPM.
Old 09-04-2020, 01:35 PM
Ramsino's Avatar
C43
I'm interested in ordering a JB4 but I don't plan on installing a BCM. At what map does the BCM become necessary?
Old 10-18-2020, 02:18 AM
jevsays's Avatar
2016 C450 AMG, 2005 C230 Kompressor
I believe all maps require BCM if you have a facelift model.
Old 10-18-2020, 08:44 AM
1Gunner's Avatar
That is exactly what BMS told me for my FL C43, so I added it when I ordered the Dragy.
BCM is not required for pre-FL C43's.
Old 10-18-2020, 11:42 PM
BMS
Former Vendor of MBWorld
BMS's Avatar
2018 C63 Sedan
Contrary to popular belief the BCM remains optional even for facelift models. It's only required if you're expecting pre-facelift like performance metrics.
When install (takes 30 seconds) it's active and provides benefit with all maps.
Old 02-02-2021, 02:48 PM
SPONSOR
RW Carbon's Avatar
Mercedes GT55 AMG
Lots of options to make sexy! Front lip and trunk spoiler. Check out this C43 we did.
https://blog.rwcarbon.com/2021/01/11...sion-diffuser/
https://www.rwcarbon.com/
Quick Reply: 2020 C43 w/ JB4 + BCM
