C450/C43 AMG
C43 Wagon Mild Build Thread
Old Sep 30, 2021 | 12:16 AM
SaKiRY's Avatar
c43 wagon
Where did you get your Vossen rims? Any links to share or in store? I am also in GTA.
Old Sep 30, 2021 | 08:06 AM
toosteeley's Avatar
Present: 2019 C43 Estate
Hit up Raffi at Tire Connection. He's also an MB True North (FB group) sponsor. https://www.tireconnections.com/
Old Oct 2, 2021 | 12:04 AM
SaKiRY's Avatar
c43 wagon
Hi Toosteeley, I might go for 19 inches Vossen CVT wheels for my C43. The front is 19x8.5 et30 which I think will fit since it is same to your 20x8.5 et30 spec. but the rear is 19x10 et55 which is 5mm inner to yours. Do you think it fit? any concerns of rubbing the lining? Thank you.
Old Oct 2, 2021 | 05:35 PM
toosteeley's Avatar
The front will be fine. I’m currently running 20x10 +40 rear. You’ll want a 10mm spacer with 19x10 +55. They will be far to tucked compared to the front otherwise. Ideal with a 10” wide rear rim would be +45 IMO.
Old Oct 12, 2021 | 06:03 PM
CO_C43's Avatar
2017 C43 Coupe
Toosteeley, I am obsessed with your build. I'll be joining you soon as another fully wrapped c43. Mine is the designo white with the saddle interior, coupe. Im going with black vossens (potentially adv.1) in the spring, and going to be wrapping satin battleship gray leaving all gloss black accents and emblems. I'm in the process of opening a wrap shop here in the US and cant wait to do my c43.
I've got a few months before I get my summer wheels and tires, running the stock 18's now with winter tires. From what I have seen, your +30/+40 sits flush but a 5mm spacer in the rear? Could you have gone with a +45 wheel and not done the spacer for the same result? I think I have my specs dialed in, but seeing different answers across forums and wheel shops.
Plan on running:
20x8.0 +30
20x10 +45
235/35/20
265/30/20
I originally was going to do a +32 but from what I saw, if you did a 235 tire, you needed a spacer. I want a 235 over a 225. Beefier the tires the better but not wanting to rub and not wanting to run spacers.
I've fit a few builds now with wheels and tires and my lord, this car is the most complex to fit.
Anyways, stunning ride. Can't wait to show mine!
Old Oct 13, 2021 | 08:14 AM
toosteeley's Avatar
Thanks for the comments! To clarify, my current setup is:
Front - 20x8.5 +43 (with a 12mm spacer bringing it to +31), 235/35/20
Rear - 20x10 +40, 275/30/20
My old setup with the Vossens was:
Front - 20x8.5 +30, 235/35/20
Rear - 20x10 +50 (with a 5mm spacer bringing it to +45), 275/30/20
Ideal rear offset on a 10" rim would be +45 IMO.
I would have preferred 20x8 +30 but wasn't able to find a rim in that size. Minimum in a 20" seems to be 8.5"
As for tires, if you're going with a 10" rim in the rear, do 275 tires, not 265.
Good luck with your new wrap shop! Satin battleship grey is a great colour. I considered something similar but my 507 was platinum magno so didn't want to go satin grey again.
Old Oct 13, 2021 | 08:22 AM
  #32
toosteeley's Avatar
For comparison, here's 20x10 rims with +45 offset and +40 offset for comparison.
+45
+40
Old Oct 13, 2021 | 05:07 PM
  #33
CO_C43's Avatar
2017 C43 Coupe
Thanks for the well wishes! With the Front - 20x8.5 +30, 235/35/20, did you have any rubbing on your upper control arm? I've seen that has been an issue with someone else who had +32... Sounds like +30 with a 235 tire is the sweet spot for fitment with no spacers and no rubbing
Old Oct 13, 2021 | 05:59 PM
  #34
toosteeley's Avatar
No rubbing on the control arm with +31 offset. Some slight rubbing on the inner fender on large dips, but it’s predictable and avoidable.
Old Oct 13, 2021 | 06:01 PM
  #35
toosteeley's Avatar
Here’s a pic of the control arm clearance. Not much, but enough.
Old Mar 29, 2022 | 01:16 PM
  #36
tkies's Avatar
2019 c43
Car looks great. What is the H and R lowering wagon spec? or order part number. I cant get a clear answer from shop about which product to use, that does have the rear of the car sag. They are saying they can find which ones to use. Is it same as sedan?
Old Mar 29, 2022 | 07:01 PM
  #37
toosteeley's Avatar
Thanks! Without looking up the actual part number, I believe the wagon specific springs are the same # as the sedan ones but with “-2” added to the end.
Edit: found the part # H&R 28811-2
Old Mar 29, 2022 | 07:07 PM
  #38
toosteeley's Avatar
Some newer pics:
Old Mar 29, 2022 | 08:41 PM
  #39
C43HeartBoost's Avatar
C43
Amazing looking car!
Old Mar 29, 2022 | 11:32 PM
  #40
BoolitSpunjBoon's Avatar
C450 AMG
Love the wagons. Kinda jealous.
Old Mar 30, 2022 | 06:51 AM
  #41
toosteeley's Avatar
Thanks! Might be for sale soon…
Old Mar 30, 2022 | 06:19 PM
  #42
AR_motorwerkz's Avatar
MERCEDES AMG GT, MERCEDES CLS63 AMG, MERCEDES G63 AMG, MERCEDES CL63 AMG
Some newer pics:
OOhhh showing off some muscle! Nice wagon man!
Old Apr 19, 2022 | 02:01 PM
  #43
Squint's Avatar
C43 AMG 2019 estate
Love the update buddy that wrap is seriously lush!
I have managed to do my original list of bits
Dynamic indicators and amg mirror down lights
Interior led vents pillar speakers and extended paddle shifters
Keeping the chrome for now, pannamericana grill and racing design front lip
Next things waiting for warranty to run out before doing my suspension (good job aswell as on my last service they replaced rear shocks due to some leakage) then a stage one tune.
