Brake boosting at speed
Durability wise probably not the best for the turbos as that's what takes the brunt of the abuse when brake boosting or using antilag...the system basically retards timing forcing combustion to happen later in the burn cycle as the piston is moving up in the cylinder forcing the actual combustion process into the exhaust and turbo housing.
some cars that cannot be tuned with an antilag system typically will brake boost to achieve the same outcome...seems like ours cant however.
The key is to press brake first!
Disregard the sarcasm, the real drivers or car enthusiasts understand and know what you are talking about. I've only had the car for 6 months and had also be wondering if and how well brake boosting works on these cars. Before I could be in the right gear and just dump the clutch to get the car into the power band quickly. I may end up just repeating what @superswiss states but we'll have some evidence to back it up.
Heh, I know this is a year old but did you end up trying it out?
