The Quest For Sub 11s 1/4 mile time
still couldn't produce that mid 11's run that he claims while on this local shop's "custom" stage 2 tune
and all this time, with all that money he spent on mods, he couldn't afford a Dragy...
BTW, what is the name of this local shop anyways?
10 sec software and not even a name?The Best of Mercedes & AMG
-Eurocharged Canadá Custom ECU/TCU files
-weistec downpipes
-bms intake
-bms meth kit
-fx-180 spool pump
-E40 fuel
-JB4 using for control meth and logging
A beefed up M276 (still stock motor and turbo) literally competes with supercars with several more cylinders (in the same year make range). Impressive is an understatement
understatement
Sounds about right, probably the max that those stock turbos can push before it fails on you. Jeff has done a lot of testing with his monstrous 43 and it's held very well it seems. WMI seems to help
I believe his car is the only car to complete the 1/4 in under 11 seconds. But another car C450 (also owned by a Jeff, here in Taiwan. We call him Taiwan Jeff) came pretty close to a sub 11 run on several ocassions as well. He also did all this on a stock motor and turbo. Then he upgraded his turbos and realized the car wasnt any faster with just turbos.
Besides these 2 a few cars have been able to trap over 124mph but this Canada Jeff is the only 1 who was able to actually complete a sub 11sec 1/4.
https://www.youtube.com/watch?v=3Tq5RaETzEg
Seems to be where I pretty much sit with the current set up I have, I really want to stay away from putting ethanol in my tank, cause it is too much of a pain with the way ethanol works at the pumps near my location, so it looks like the next step is ready to take place.
What is this next step? METH KIT. This will allow for better cooling, no mixing/testing headaches, but also will allow me to raise the boost safety on my jb4 by a PSI or 2 (it's currently sitting at 20 Peak PSI Boost safety)
Will keep y'all updated!
then u can see your improvement & people can help you more
