Euro Charged
#51
thats what i dont get before it would drop to 2500 psi max playing with e85 blend i see it at 1600 now filled tank with 91 pump now only drops to 2100 psi not sure i might be going to high on the blends i watched a video of Brett logs the guy that claims his engine blew his psi hits bout 2150 psi maybe damaged pump seals .
#52
#58
Yes sir car is running great. I was able to do a 3.84 0-60 and I did an 11.84 quarter all measured with dragy. I am think of my next upgrades atm. I'm looking at the intercooler and hfc. But really how much more can I gain? The real problem with this platform is that boost falls off up top and doesn't hold. I am also thinking if I should just lay her off and get a c63s because all manufacturers are going to smaller engi es and motors... is there anything you are looking for specific?
jevsays (04-10-2021)
#59
#60
Right on man. Yeah these cars are capable to run in the 10's. The above photos i posted are from November. He has hit the 10 second mark with Eurocharged tune, Meth injection and what was stated earlier the JB4 to monitor the meth injection. My next mod i think will be the meth injection and HPFP to run e85. Keep up the mods and let us know how it is going.
Howyalivin (03-16-2021)
#61
Darrington (03-17-2021)
#62
That's what I've heard and where I will be going. Plans are for HPFP, Wagner Intercooler and Meth injection. I'm also under the impression that I need to replace the LPFP too? Do you know if that is true or not?
#63
but if you can swing it, its a good idea to have it regardless. oem LPFP holds 45-50psi with e30 under load. Upgraded LPFP by martin tuning holds 80-90 psi under load e30. They are doing testing on full e85 now.,
MeerC450 (03-18-2021)
#64
Thanks i been contemplating whether to get the LPFP or not, running e30 now.
#65
Well a little update, I went with the Logos Engineering Motorworks downpipes, though I will have to get a retune from EC to go stage two to see the results. I'm not sure how much difference this will make but I'm hoping for some more tq down low and some hp up top. If anyone has them installed feel free to chime in and let me know what ya think. If I like the quality, fit, and finish I will see what other products they have!
#66
2004 E55 K Wagon &. '96 SL500
