Soon to be new owner questions.
Below is a list of the maps, their boost increases, and what BMS says about each. This is their info, not mine:
JB4 Map Guide as of v6 firmware:
Map 0: Disables tuner
Map 1: Up to 4psi over stock peak, suitable for all 91 octane+ fuels
Map 2: Up to 5psi over stock peak, suggested for 93octane+
Map 3: Up to 5.5psi over stock peak, slightly more aggressive version of map2
Map 4: Up to 6psi over stock peak, suggested for E30+ or unleaded race gas mixtures
Map 5: Up to 7psi over stock peak, holding more boost to redline, suggested for E30+ or unleaded race gas mixtures
Map 6: User definable map, boost over stock entered on user adjustment page
Map 7: WMI (water/meth injection) progressive map for BMS FSB integration
Map 8: Low boost VALET map
Herrerrera (05-27-2021)
The JB4 has multiple maps that add increasing amounts of horsepower. I don't know that I have seen anyone dyno their car on different map settings. You said earlier in the thread that you were looking for 30 whp, and you can definitely get more than that even in the lowest settings. Map 1 usually runs low 12s. Map 2, another 10th or 2 faster, usually in the 11's. Map 3, a fraction better than that. There are more maps beyond that, but it doesn't seem that you want to go past 3.
Make sure to not choose a map that you aren't running enough octane for. If you have 93 octane, Maps 1 and 2 should be fine. Ask them about 3, otherwise, use something like boostane if you plan to run map 3. Map 5 should definitely use race gas or a mix of ethanol and 93 pump.
Herrerrera (05-28-2021)
And you do want to add in the bluetooth adapter.
Received 2,843 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
#32
https://burgertuning.com/collections...-mercedes-benz
The wireless mobile connection?
#33
Herrerrera (05-29-2021)
#35
I helped you find some videos of the pfl car without the performance exhaust (PE) which they only have the standard sport exhaust:
youtube.com/watch?v=uBWonOJDiAo
youtube.com/watch?v=4f3Lg7Vi_zQ
youtube.com/watch?v=3u_41GLi7gk
Since you already got your car, even without PE you should still be able to enjoy it, once you push it in the high revs, it can still sound pretty good
#38
If this legit? https://www.racechip.us/shop/mercede..._source=Criteo
Herrerrera (06-03-2021)
#39
in aware the jb4 puts out much more power. But I'm worried about stressing the motor over time.
#40
#41
