For all tuned C43 owners, which gas station do you go? Canada specifically.
I ran tests, Petro produces more power because of advanced timing with the 94 octane. But the benefits of shell is more KMs and seems to be louder and pop more.
Have not done a track day where I didn't run 94, so can't compare ... and I don't consistently push the car on the streets to notice any difference (it's that "floor it for more than 1-5 seconds and you're into impound speed" issue).
Now, ethanol itself is not bad for an engine. It's the affinity to water by it and other alcohols that can cause problems by the way of ethanol corrosion. This is due to the elevated levels of water held in the gasoline corroding the internal components of the engine. This however is not really too much of a concern where the infrastructure and distribution networks keep water contamination relatively low.
I actually run E30 (E85 blend) in my BMW as i get really good performance gains compared regular unmixed 91/94. Also thousands of others also do running similar set ups with absolutely zero problems. Saying ethanol is always unhealthy for your engine is just plain wrong.
