Does it fit?
R1591985F4+35 Black Rotiform OZR 19x8.5 35 2020 Mercedes-Benz C43 AMG AWD 5x4.41,5x112
15572740000 Continental ExtremeContact DWS06 PLUS 225/40ZR19 2020 Mercedes-Benz C43 AMG AWD 5x4.41,5x112
15573130000 Continental ExtremeContact DWS06 PLUS 255/35ZR19 2020 Mercedes-Benz C43 AMG AWD 5x4.41,5x112
Thank you!
As for the wheel itself, you will definitely need extended lug bolts. The front will be pretty much flush but the rear will stick out.
There are online calculators you can use to compare stock vs new, hope this helps.
Sounds like they'll fit but may not be the ideal set up?
I'm concerned they won't fit or rub considerably. Can you link me to this calculator? Do you know of anyone who is running the same size / similar set up? The tires can be changed, my biggest concern is the wheel won't fit. Any recommendations on the ideal set up? What tires do you recommend on these rims??
thanks again!!!
lowering/not lowering impacts feedback.
the thread is as comprehensive as information as you're going to get - if you don't now how to interpret it, copy someone else.
If you are lowered, 8.5 wide front et30 will clear the inner arm. If you are not lowered, this will stick out in the front. Some don’t mind, others feel this isn’t flush.
Non-lowered safe zone that I gathered as done on 43’s…
Front: 19x8 / 20x8 et30-33. With 225 tire. (235 tire if also going wider in the rear.)
Rear:
19x9 / 20x9 et44 with 255 tire.
19x9.5 / 20x9.5 et48-52 with 265 tire for 19s. (275 for 20s)
Please use a calculator similar to this one…
https://www.1010tires.com/Tools/Whee...et-Calculator#
and please reference the wheel thread for more information and examples.
The only thing I’d correct on the above is the rear offsets. From personal experience, A 9.5” width rim should ideally be in the +40 to +45 offset range to visually match the front. More than +45 will move the rim too far inside the fender IMO.
