Issue with Ignition coil 6
Swapped another good coil into cylinder #6, changed the spark plug, and misfire continues to happen in cylinder 6. I have noticed that it mostly happens when I'm driving steady without breaking for a long time (like in the highway) and then come to a stop. Using an icarsoft, I got the code P2315 and reads "the actuation of ignition coil 6 has a short circuit to ground". The ground for the coil was cleaned, but this did not fix the issue either. I have not seen anyone on this platform with this issue, but I can't believe I'm the only one out there. If anyone has any idea of what it could be or has gone through something similar, please help!
Aside from confirming that, what others have said is where i would start...tracing the connector at the coil back through the harness looking for rub/chewed spots.
Unfortunately yeah, I'm sure. I even changed all the plugs and coils around, but the misfire continues in cylinder 6. I took it to a shop, they did pretty much the same thing I did as well as clean the ground where the coil sits, but the misfire continues to take place. I tried taking it to the Benz dealer, but they wanted an arm and a leg jus to run some tests. For a C class, it's just not worth it regardless of how much I actually like the car.
