C450/C43 AMG
Wheel alignment & battery change
Old Nov 30, 2021 | 03:33 AM
speranza's Avatar
2018 C43
Old Nov 30, 2021 | 07:16 AM
SchneWe's Avatar
MY19 C43
1. So long as the tyre shop is competent, there likely would not be much of a difference in the alignment. These days they use lasers to align so unless the tyre shop is eyeballing it there should be no appreciable difference.
2. Not sure if $890AUD is inclusive of install, but that seems pretty steep. If I am remembering correctly you can get aftermarket AGM batteries for ~$450-475AUD. Heck, you could get Varta batteries for ~$550, Varta being the german OEM who makes the Mercedes batteries last I checked. I also don't believe mercedes vehicles require their batteries to be programmed, unlike BMWs. Then factor in probably $50-100 install if you're not able to install yourself. So even if you go down Varta route and pay someone $100, It's $650 and that's $240 saved.
Though I might be over-estimating how much the fitting costs.
Old Nov 30, 2021 | 07:43 AM
speranza's Avatar
2018 C43
Smile
I agree with you, it does seem a bit steep. Thank you for replying.
Old Nov 30, 2021 | 10:42 PM
0dte's Avatar
C43 EC Stg 2, 380SL
At the dealer's price point, may as well consider one of these instead: https://antigravitybatteries.com/pro...tive/ag-h5-rs/
Old Nov 30, 2021 | 11:45 PM
speranza's Avatar
2018 C43
Thanks Odte, I’ll look into this. Thanks for taking the time out to reply.
Old Dec 1, 2021 | 04:58 AM
Freder8d's Avatar
2017 AMG C43
My dealer told me a year ago that the battery need to be replaced but I thought it was premature and have driven on it since for over a year until just lately the warning light says stop vehicle leave engine running. I drive it for a little bit after warms up and when I restart the car the light goes away. The battery is failing ultimately and I'm looking at replacement as well. I'm considering the optima yellow top. The dealer out here quoted $600 for replacement battery which I think is absolutely ridiculous.
Old Dec 1, 2021 | 05:13 AM
speranza's Avatar
2018 C43
Thanks Freder8d, I think I’m going to wait until I get a message from my car.
Old Dec 1, 2021 | 11:12 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
I've seen lots of shops that aren't MB specialists mess up alignments, so its certainly possible.
Old Dec 1, 2021 | 07:25 PM
speranza's Avatar
2018 C43
ok thanks.
Old Dec 1, 2021 | 07:46 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
OK, but the message might be "Sorry. I will not start. Call a cab."
Old Dec 1, 2021 | 08:09 PM
speranza's Avatar
2018 C43
lol…..a thoughtful car recommending a plan of action.
Old Dec 5, 2021 | 07:56 PM
japlaza's Avatar
2017 c43 amg coupe
Optima Yellow Top is an excellent choice. Changed mine about 3 days ago, around $335 US + tax. Message "stop vehicle leave car running" completely gone. It means the battery is not holding much charge unless you do a long drive. The battery may last some time, but on the long-run it will die.
Old Dec 9, 2021 | 02:19 PM
TOOGECKO's Avatar
AMG GLC43
Just replaced mine after getting the "Stop Engine... " Warning message and trying to see if it would consistently reset for a week. If I have learned anything about car maintenance, it's that there is no such thing as a planned battery failure!
Old Dec 9, 2021 | 09:34 PM
japlaza's Avatar
2017 c43 amg coupe
Well, yes I do agree that there is no such thing as a "planned battery failure". But it is also true that when a battery begin loosing its storage capacity, it will fails at some point in the near future. It will be ok if the car is used on a daily basis and so on, but leaving it parked a couple of days it may not start-up. Is not a maintenance issue, is life span of the equipment.
At least in my case I haven't got again the message since the battery change.
Old Dec 20, 2021 | 04:18 AM
Freder8d's Avatar
2017 AMG C43
Ended up going with this battery. It has a higher cca and bigger battery reserve for less $ than an Optima yellow top.
https://www.batteriesplus.com/produc...er/sli94ragmdp
