C450/C43 AMG
Terrible stock paint
Old Sep 8, 2023 | 04:47 PM
BigTurboC4's Avatar
C43. GS-T Spyder. 20th AE GTi.
Is the stock paint on w205 C43 as bad for everyone else as it is for me? It seems to be one single layer of color over a layer of primer. Any ding I get immediately shows white underneath and looks as though I could peel it off in chunks. Is this typical or did I get the worst paint known to man?
Old Sep 8, 2023 | 09:52 PM
jonathan358's Avatar
2018 Mercedes C43 AMG Coupe
You might have got a bad batch, Mercedes OEM paint is one of the best. Very thick.
Old Sep 9, 2023 | 09:44 AM
W205C43PFL's Avatar
no paint problems on my 2017, what year is yours?
Old Sep 9, 2023 | 09:45 AM
W205C43PFL's Avatar
The German factory and the Alabama factory uses different standards in painting vehicles (due to regulations) back then, so the coupe might have more robust paint than sedan, although I think the German factory did transition in the recent years as well. That said, my paint although not as good as the coupe ones aren't as bad as OP is stating so curious what model year is OP's vehicle.
Old Sep 9, 2023 | 10:03 AM
chassis's Avatar
2017 GLE350 4MATIC
100% normal. MB paint is not thick. It chips easily, particularly on the hood leading edge.
MB paint might have been thick on the W100 Grosser. No longer.
Old Sep 9, 2023 | 01:06 PM
superswiss's Avatar
2019 C63CS
It has been reported in the past that the paint quality coming out of the Alabama factory is subpar and the German built cars have better paint. I have no issues with the paint on my 2019 C63 coupe built in Germany. In fact it seems stronger than previous cars. FWIW, I do have PPF on the entire front to protect the high impact areas, but I drove the first ~6000 miles w/o PPF in Europe. I did the same with my previous Audi, but about half the miles and the Audi already had a few paint chips before the PPF went on. The C63 had zero chips when I put the PPF on and the paint looks like the day I took delivery even in the unprotected areas. Car is garaged, so no prolonged exposure to UV light and other damaging environmental factors. It's also mostly dry here, so no acid rain and such. I never even wax it, other than what comes out of the touchless car wash I go to near my place.
Have you checked if some of your panels may have been repainted? There's always the possibility that the car sustained damage and needed to be repainted, or it is possible that you might have gotten a bad batch.
Old Sep 9, 2023 | 01:56 PM
user33's Avatar
It would be interesting to see some actual paint-thickness data from a proper meter across a collection of cars in the same model but with different manufacturing locations.
Old Sep 9, 2023 | 02:20 PM
superswiss's Avatar
2019 C63CS
I'm not sure there will be a difference. They have the same standards as far as how many layers of paint go on the car. More telling would be a chemical analysis of the paint and prep solvents they are using due to different environmental regulations at each location. Climate factors also play a role. It's more difficult to paint something in a humid vs a dry climate, so it'd be very interesting seeing the drying times between different locations.
Also, keep in mind that paint needs time to harden. Cars produced in Germany and shipped to the USA spend much longer not being driven on the roads, so the paint has more time to harden before a customer is taking delivery.
Old Sep 10, 2023 | 12:04 PM
user33's Avatar
... Climate factors also play a role. ...
Agreed ... but specifically WRT climate, I'd bet the painting environment is extremely well controlled in any production facility.
Old Oct 3, 2023 | 09:45 AM
BigTurboC4's Avatar
2017. The rear bumper cover is where it's most noticeable.
Old Oct 4, 2023 | 05:00 AM
ygmn's Avatar
2015 E400 Sedan
robots paint these cars sp applied with great physical results and repeatable across a production run.
Thick paint does not make for a better more robust paint - in fact can chip easier since more potential for lamination between more layers.
Thick paint layers is not desirable neither since it will orange peel like crazy due to out-gasing while curing and is more prone to waviness in reflections
Main issue with paint today is all the environmental rules and trying to get rid of VOC and other bad atmosphere chemicals.
Nice looking paint job comes down to clear coat - to make it look better have it wet sanded and polished (aka paint Correction) as no paint coming out a spray gun can ever look as good as one wet sanded.
Old Oct 7, 2023 | 04:58 PM
W205C43PFL's Avatar
not sure if this the right video but she talked about the paint on her C 63 S:
Old Oct 7, 2023 | 05:13 PM
superswiss's Avatar
2019 C63CS
not sure if this the right video but she talked about the paint on her C 63 S: https://www.youtube.com/watch?v=ta1SAMdOGQ4
Not sure what it got translated to in the subtitles, but all she said about the paint is that it is brand new under the wrap. She had it wrapped shortly after taking delivery, so she pointed out that there were no rock chips for example. Problem with a wrap is always that the paint could be damaged when removing the wrap, especially if it hadn't fully hardened before the wrap was put on.
Old Oct 7, 2023 | 06:24 PM
W205C43PFL's Avatar
Sorry about that. My bad then that is not the video. I remember she posted a video on comparing the paint thickness of each panel. Let me try to look for that video again.
Old Oct 7, 2023 | 06:25 PM
W205C43PFL's Avatar
It could be this video, I am not sure:
