C450/C43 AMG
Metal Rubbing?
Old Mar 17, 2024 | 01:33 AM
Abdullium's Avatar
2021 C43 Amg
Metal Rubbing?
I have another video but can someone please tell me what this noise is
Turn up the volume
File Type: mov
Old Mar 17, 2024 | 09:54 AM
W205C43PFL's Avatar
Turn up the volume
I can't hear what you are talking about maybe I have a bad ear or a bad speaker, which part of the video is the loudest?
Old Mar 17, 2024 | 11:13 AM
S205.C43's Avatar
2020 C43 Wagon
Sounds like the sound is coming from a rotating part? Could it be the rotors?
Old Mar 17, 2024 | 10:17 PM
Abdullium's Avatar
2021 C43 Amg
You will hear it the whole vid its like a really awkward noise
Old Mar 17, 2024 | 10:22 PM
Abdullium's Avatar
2021 C43 Amg
like brake rotors no way ill post another vid
Old Mar 17, 2024 | 10:23 PM
Abdullium's Avatar
2021 C43 Amg
Raise the volume and you'll hear like a really like a whirring noise
File Type: mov
Old Mar 18, 2024 | 08:22 AM
W205C43PFL's Avatar
Ah I hear it, sounds like a wastegate although still pretty far from it but then it does sound like brake pads grinding rotors like another forum member mentioned. Please keep in mind that brake pads are always touching on rotors even if you are not braking so it doesn't have to move into position when you apply the brakes improving safety. It is just that, when you don't apply brakes, it doesn't apply any pressure.
Does the sound get louder when you cold start and drive in the morning and/or when outside temperatures are low?
Old Mar 18, 2024 | 08:24 AM
W205C43PFL's Avatar
https://mbworld.org/forums/c450-c43-...ate-issue.html
Old Mar 18, 2024 | 03:28 PM
Abdullium's Avatar
2021 C43 Amg
no the sound happens when i’m on the gas a and the turbo gets to max on the dial so you think that gargling noise is the brake pads?
Old Mar 18, 2024 | 03:33 PM
Abdullium's Avatar
2021 C43 Amg
his videos don’t work so i can compare the sounds
Old Mar 18, 2024 | 04:10 PM
W205C43PFL's Avatar
Worth checking, make sure it isn't a stuck piston or anything.
Old Mar 18, 2024 | 05:13 PM
Abdullium's Avatar
2021 C43 Amg
yea cause it gets super annoying knowing something is wrong
Old Mar 18, 2024 | 05:23 PM
W205C43PFL's Avatar
Hopefully it is an easy fix.
Old Mar 18, 2024 | 09:30 PM
Abdullium's Avatar
2021 C43 Amg
hopefully cause even when I let off the gas my cold air intakes make a really like nasty airy noise that's not normal
Old Mar 18, 2024 | 11:25 PM
C43HeartBoost's Avatar
C43
Did you buy your car already modified?
Old Mar 19, 2024 | 05:41 AM
W205C43PFL's Avatar
Hmmm, good point... re: air noise, is it some aftermarket intake. Can you show us a picture and/or video under the hood?
Old Mar 19, 2024 | 01:30 PM
Abdullium's Avatar
2021 C43 Amg
No i did it all
Old Mar 19, 2024 | 01:31 PM
Abdullium's Avatar
2021 C43 Amg
they are after market intakes but they never made the noise like that gargling noise just does not sound like air you know
Old Mar 19, 2024 | 11:02 PM
C43
No i did it all
Then take it back to the shop that performed all the work. End of story.
