C450/C43 AMG
Will KW V3 make ride softer?
Old Apr 19, 2024 | 12:13 PM
altay's Avatar
2020 GLC300 4matic, 2017 C300 4matic
Hi guys,
i have 2020 c43. In general I like my car only issue is when I hit imperfections on the road like reflectors, suspension feels so stiff. It feels like when a car’s tires overinflated. Even I put Michelin PS4S and put 30 psi cold still feels same. If I install kw v3 with soft settings do you guys think will it be softwr than OEM?
thanks for replies
Old Apr 20, 2024 | 09:51 AM
C43HeartBoost's Avatar
C43
I have never seen an instance where aftermarket springs performance make a car ride softer. I have the non-adjustable H&R springs, and the ride is VERY firm - which I like for my purposes.
Old Apr 22, 2024 | 12:19 PM
altay's Avatar
i am talking about coilovers not just springs. Springs are definitely make ride stiffer
Old Apr 22, 2024 | 07:18 PM
C43
Same answer.
Old Apr 22, 2024 | 10:55 PM
M Kompact's Avatar
2020 C43
Ride quality is very subjective, if it bothers you to that degre you may need to look at buying something else. My wife and I find the ride in my 2020 C43 to be totally fine- even with 19" wheels and OEM MOE tires.
Old Apr 23, 2024 | 06:19 PM
AXO893's Avatar
2019 W205 FL C43 AMG Saloon Selenite Gray
I know Koni's ride pretty soft on my GTI. I'm not sure they make them for the C43 AMG though.....
Old Apr 23, 2024 | 06:32 PM
M Kompact's Avatar
2020 C43
Koni doesn't make anything for the W205. Bilstein sells a B4 OE replacement in their DampTronic line- front only.
Old Apr 25, 2024 | 12:55 PM
S205.C43's Avatar
2020 C43 Wagon
I recently changed to Michelin PS4S’s on the stock 19” wheels and it has noticeably improved the NVH and handling over the MOE run flat tires the car came with.
Old Apr 25, 2024 | 03:56 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Coming from my Honda/Subaru days you can have stiff spring rates and a comfortable ride. It just depends on the dampening. If you run full soft and daily drive you can honestly enjoy a really nice ride.
I use the V3's on a 911 and I'm so much happier with those for ride comfort/travel/shock speeds than the stock Bilstein B4 setup. You're going to be very happy with the V3's if you set them up properly and allow yourself an acceptable amount of suspension travel. A new Lexus ES is under damped and i will rebound 2-3 more times after any dip on the freeway and is far worse than any modern coilover setup properly tuned.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Apr 25, 2024 | 06:17 PM
W205C43PFL's Avatar
To be fair, the facelift C 43 had revised suspension dampening via software (forgot if the actual hardware was changed as well) but I test drove a few and it was always much softer and comfortable compared to my pre-facelift.
Here are the changes I found out back then: https://mbworld.org/forums/c450-c43-...ml#post8858401
Old Apr 25, 2024 | 06:43 PM
altay's Avatar
Thanks for answers. Car is not that stiff just feels like short sidewall of tires causing more impact feel hitting on imperfections on the roads. Maybe I should go with 18 inch wheels with more sidewall. Other than that I really enjoy it.
Old Apr 25, 2024 | 06:56 PM
W205C43PFL's Avatar
That is a good idea, sorry to hear that going to non run-flats PS4s and adjusting the tire pressure wasn't enough to help though. I wonder if you go forged wheels it might help as well?
