Looking at C43 AMG
Looking at C43 AMG
I am coming from a B8.5 Audi S4 that I sold and I am deciding between a B9 S4 and a 18-20 C43 Amg. My questions are how reliable are these? What do I look for/not look for when buying one.
Second questions is I have seen several stage 1 ECU tunes but can't seem to find and TCU tunes, Why is that? The few I have found are 2k+. Does stage 1 ECU require bolt ons and or do you recommend any mods?
Thank yall in advance.
Received 2,843 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
The transmission jerkiness is something you need to live with because it is honestly the worse part of the entire car so you really should test drive and see if it is too much for you.
The body roll in corners is another issue but it isn't very bad, but it is there.
Depending on how much you like sound, you might want to get the PE (performance exhaust), do not get 19s or 20s because they crack easily, unless you go aftermarket wheels and tires. Recommend getting facelift so 19 and 20 because of the following that I compiled in a list after comparing the two, you may also go through that thread as it talks about reliability as well: https://mbworld.org/forums/c450-c43-...ml#post8858401
Since I like to keeping mine stock (other than the oil pump solenoid mod), my apologies first that I have no comment on the TCU tuning.
I appreciate the response! As long as the jerkiness doesn't cause issues I don't really care the S4 DCT was pretty jerky overall. I assume oil pump solenoid mod is for reliability reasons?
Ah, the oil pump solenoid. Where should we start, here is a good read (it is the longest thread on this forum but read the FAQ at least): https://mbworld.org/forums/w212-amg/...solenoids.html
In regards to the TCU:
https://mbworld.org/forums/c450-c43-...imitation.html
https://mbworld.org/forums/c450-c43-...eak-spots.html
Some details on the engine:
https://mbworld.org/forums/c450-c43-...v6-thread.html
I was looking at an Audi S5 Sportback before purchasing my C43. I ultimately went with the Mercedes. The C43 was a little more expensive, but I loved the throttle response and the handling was better then the S5. Plus I have the Performance Exhaust option which pretty much sealed the deal. I've had mine for two years now and luckily no issues. Mine is completely stock except a set of K&N dropin air filters and cabin filter.
My C43 and My Almost S5.
C43
The c43 is super reliable had about 90k miles on a 2019 and jb4 since 20k miles ….floored it everywhere a I have a heavy foot 😅 anyway I have a jb4 for sale since I traded the car in if interested
C43 Cmac Custer (05-16-2024)
