C450/C43 AMG
2020 C43 Coming Off Warranty
Old Aug 14, 2024 | 11:23 AM
ScottC43's Avatar
CLE300
I have a 2020 C43 with just under 25K miles. It’s paid off. am concerned of course retaining a vehicle that is complicated and expensive to repair. I am not interested in a 3rd party warranty.
I realize there will be many differing opinions whether to keep it or not.
I drive it about 5K miles per year.
I appreciate your opinions and guidance.
Old Aug 14, 2024 | 11:37 AM
W205C43PFL's Avatar
I drive it about 5K miles per month.
Have a 2017 sedan been reliable, mostly minior annoyances like squeaks and rattles. Been out of warranty for a while no complaints.
Old Aug 14, 2024 | 11:39 AM
ScottC43's Avatar
CLE300
C43 Sedan? What maintenance items other than routine have you had to do. How many miles may I ask?
Old Aug 14, 2024 | 11:43 AM
eagle_lex's Avatar
2012 E350 4matic
Nice car sir. I have a 2016 C450 with 97k miles. The car has needed nothing other than routine service and of course tires/brakes/plugs/filters. I plan on driving it another year or so until I can hopefully get a newer W206 C43. I would not be worried.
Old Aug 14, 2024 | 11:47 AM
ScottC43's Avatar
CLE300
Much appreciated. Thank you!!
Old Aug 14, 2024 | 11:49 AM
ScottC43's Avatar
CLE300
Thank you for your input. Repair costs especially these days are out of control based on parts and labor. It just has me worried.
Old Aug 14, 2024 | 12:02 PM
W205C43PFL's Avatar
You're welcome.
​​​​​The main problem with this car is the trash runflats and rims susceptible from cracking which is easily resolved by going aftermarket.
Just talking about maintenace wise, depending on your mileage tranny fluid might be due, differential fluid, sparkplugs, brake fluid is every 2 years, etc.
Old Aug 14, 2024 | 12:08 PM
W205C43PFL's Avatar
Here is what I posted last time, a general idea of what to expect. In the coming years. https://mbworld.org/forums/gle-class...ml#post9003483
Old Aug 14, 2024 | 12:14 PM
ScottC43's Avatar
CLE300
You're welcome.
Much appreciated. I’ve swapped out my run flats. Fluids can be done at a local independent not having to go to Mercedes.
Old Aug 14, 2024 | 12:33 PM
W205C43PFL's Avatar
You're most welcome : )
Old Aug 14, 2024 | 12:55 PM
eagle_lex's Avatar
2012 E350 4matic
You are welcome sir. I have only done fluids, filters, rotors, pads, tires. And, YES the run flats are trash. Michelin PS4 all seasons work great IMO.
Old Aug 14, 2024 | 01:01 PM
ScottC43's Avatar
CLE300
Great information. I really appreciate it. Yes run flats are horrible. Had them on the car for 8 months and swapped them out for Continental Extreme Contact DWS06 Plus which I love. Major improvement in ride. Filters except oil I do my self with OEM filters. Fluids at local independent.
Old Aug 14, 2024 | 02:27 PM
W205C43PFL's Avatar
Another vote for PS4 summer tires from me : ) transformed the car for me.
You are lucky you have the improved dampening software from the facelift suspension, the pre-facelift ride quality is brutal.
Ride quality is the thing I hate the most about the car and on top of the 19s and runflats, aftermarket 18s with PS4s summers helped but still very poor ride quality, it is no C 300 ride quality in comfort I get it and expected that but the facelift which you have has much needed improvement to ride quality.
Old Aug 14, 2024 | 02:28 PM
W205C43PFL's Avatar
Depending on how long you wish to keep the vehicle, OP, you may consider the oil pump solenoid delete mod. More on it here https://mbworld.org/forums/w212-amg/...solenoids.html
Old Aug 14, 2024 | 02:35 PM
ScottC43's Avatar
CLE300
Definitely a stiff ride. Uncomfortable and jarring at times but still love the car.
Looks wise incredible.
Old Aug 14, 2024 | 02:38 PM
W205C43PFL's Avatar
I understand the facelift ride quality is still bad but you need to drive a pre-facelift : ) the ride is brutal, the facelift improved so much. They use the same springs, I compared the part number but the software installed in the facelift is magical.
Old Aug 14, 2024 | 02:42 PM
W205C43PFL's Avatar
Actually, I realized I came up with the a list of things back then on what the improvements and differences the facelift had compared to the pre-facelift : https://mbworld.org/forums/c450-c43-...ml#post8858401
Old Aug 14, 2024 | 02:43 PM
W205C43PFL's Avatar
Then there is also this : https://mbworld.org/forums/c450-c43-...new-parts.html
Old Aug 14, 2024 | 02:48 PM
ScottC43's Avatar
CLE300
Great info. The only real problem I’ve had is rear brakes tend to wear quickly and radar sensor unit behind front grill emblem has had to be reflashed and replaced. Due to warning appearing for no reason.
Old Aug 14, 2024 | 02:54 PM
W205C43PFL's Avatar
Glad to help!
That is an easy solution, if you have DISTRONIC it likely uses the rear brakes, if you lose traction, it likes to use the rear brakes to bring the vehicle back in control.
You should use ESC Sport instead or you can turn it off altogether, I did the latter and the ESC is not really fully off even if turned completely off, as long as you know what you are doing and not driving like a maniac or driving in the rain, that is enough to keep the car stable. If you are not comfortable with off then stick with sport. It should help conserve the rear brakes.
Old Aug 14, 2024 | 03:47 PM
MatthewJ's Avatar
'15 C400 and '15 ML350
5k miles a month? That is a lot of miles. Would definitly look at some kind of CPO warranty that covers additional years and unlimited miles.
I have the oldest of the W205 M276 models and have had very little issues. Just normal maintenance.
Also, how long have you had the car for? I see the offleaseonly plate which raises some concerns to me. They have a reputation for low prices but often sell ones with previous accidents, issues, etc. So much so, my bank even asked if i was getting a car from them before they would give a loan bc they have been burned by cars with issues that dont hold above the loan value.
Old Aug 14, 2024 | 03:50 PM
ScottC43's Avatar
CLE300
wow major mistake 5K per year. Have to figure out how to edit that. Thank you. I have under 25K miles currently
Old Aug 14, 2024 | 03:55 PM
ScottC43's Avatar
CLE300
Glad to help!
Dont have Distronic feature.
Old Aug 14, 2024 | 03:57 PM
ScottC43's Avatar
CLE300
I drive the C43 5K miles a year NOT 5K per month. Could not edit the mistake. I have under 25K miles currently
Old Aug 14, 2024 | 04:42 PM
W205C43PFL's Avatar
The edit is time based, you will need to report your own post to a moderator and state you want to edit it and to what.
