C450/C43 AMG
what is this reservoir in the engine
Old Oct 14, 2024 | 12:27 AM
kurimi's Avatar
what fluid goes in this reservoir?
Old Oct 14, 2024 | 04:50 AM
ygmn's Avatar
2015 E400 Sedan
looks like coolant.
Check owner's manual to be 100% sure
Old Oct 14, 2024 | 06:50 AM
W205C43PFL's Avatar
Originally Posted by ygmn
looks like coolant.
Yup definitely coolant.
Old Oct 14, 2024 | 07:48 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Same thing that is leaking out of the other reservoir to its left....with the exact same cap.
Now, why is your coolant leaving under the cap of the expansion tank?
Old Oct 14, 2024 | 08:35 AM
W205C43PFL's Avatar
It could be the cap, that was a common issue, if I recalled correctly the cap part number was superseded.
Old Oct 14, 2024 | 12:55 PM
kurimi's Avatar
thanks everyone. the coolant color in this reservoir is yellow, compared to the pink to the coolant reservoir to the left. does it use the same coolant? would i need to flush this reservoir?
Old Oct 14, 2024 | 02:04 PM
W205C43PFL's Avatar
Here is the answer to your question : ) https://mbworld.org/forums/c450-c43-...x-coolant.html
Old Oct 14, 2024 | 05:51 PM
TwoC400s's Avatar
2015 C400 4MATIC Palladium Silver Metallic
They are separate cooling loops, but use the same specification of fluid: Mercedes Benz 325.6 specification.
You should flush the yellow fluid and replace it with the correct fluid.
