C450/C43 AMG
Transmission going to neutral
Old Oct 25, 2024 | 09:03 PM
shaungrey's Avatar
C43
Hi everyone, I have had two episodes over the past month or so where my transmission went into neutral on its own. First time was when I was creeping forward to park in my garage, and the other occurred as I was nearly stopped for a stop sign. Both times I was hardly moving. Car went back into drive right away once I realized I was in neutral and put it back into drive. Anyone else have this kind of issue or know if it’s a sign of a major issue? Car is a 2021 with only 18k miles on it. Not abused nor tuned.
thanks for any input!
Old Oct 26, 2024 | 01:09 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ACTING UP TO GET SERVICED...
This means network disruption. Couple modules are interacting poorly to request attention...
You should get your chassis scanned by a MB Specialist or buy a LAUNCH Elite MB scanner for less than half diagnostic price.
Let us know the fault description shown in your scan. This is unlikely major unless chassis gets in a traffic wreck.
Old Oct 26, 2024 | 09:32 AM
W205C43PFL's Avatar
Common
https://mbworld.org/forums/c450-c43-...condition.html
https://mbworld.org/forums/c450-c43-...g-neutral.html
https://mbworld.org/forums/c450-c43-...on-issues.html
Old Oct 26, 2024 | 09:39 PM
Cell1's Avatar
2018 C43 AMG
Get a transmission fluid change first, IF that doesn't work, then it will likely be a busted valvebody. Same thing happened to my C43 but at 63,0000 miles. After getting the valvebody replaced, get a full trans fluid flush or else you might have issues with shifting 1-2-3-4 after..
