C450/C43 AMG
2020 C43 DRL is yellowish and not bright white as much
Old Dec 2, 2025 | 08:06 PM
hxmzh1's Avatar
W205 2020 C43 AMG
Lightbulb 2020 C43 DRL is yellowish and not bright white as much
Just picked up a w205 C43 with 48,500 miles on the dash. It is a very well kept car besides a little curb rash. I noticed today that the DRL is not bright white all the way through. Has anyone ever encountered this issue? Any response is appreciated. Will upload pictures after I get the car washed lol
Old Dec 3, 2025 | 02:34 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
weak voltage hue
The LED headlights + DRL are regulated by electric pulses of DC voltage: PWM.
The light output is highly dependant on HEAT & VOLTAGE despite the brightness being managed.
If you want bright white you can float charge (CTEK) the main battery.
In addition...
NOTE: the DRL Modules are coded to use lower power at night and high power daytime.
NOTE : the high heat in engine bay is used to cool the LED HL with fans - Realize higher light output with cooler engine on highway. Hotcity driving is dimmer output because of heat.
Old Dec 3, 2025 | 03:01 PM
hxmzh1's Avatar
W205 2020 C43 AMG
Thanks!
Thanks for the detailed response. This car is mostly going to be driven on the highway, and it’s pretty chilly in Texas right now, around 40 F. Should I just use a trickle charger to charge the battery?
Note: car was on a trailer for about 3 days since it was being delivered from Florida.
Old Dec 3, 2025 | 03:07 PM
Yes, that would be perfect.
Many starter batteries are AGM types.... Don't set charger mode as "AGM Mode" on the starter battery while connected to the car.
either disconnect it or use the non-AGM battery float mode.
Old Dec 3, 2025 | 04:35 PM
hxmzh1's Avatar
W205 2020 C43 AMG
Don’t know what agm means lol
What’s AGM mode? Also you might have to educate me on how the battery system works in this car lol
also if I’m leaving the car in the garage overnight should I leave it connected to a trickle charger as a regular practice?
Old Dec 3, 2025 | 04:58 PM
Post Starter Vs. Traction
What’s AGM mode?
How many batteries and what types are they ?
- starter - AGM 12V cells use a solid gel lead-acid chemistry.
- traction - mild hybrid-power 48V or greater storage cells.
Both types are different & unrelated.
On the MB-USA website you may find a pdf user manual for your new car. Battery care will be detailed... lol
Old Dec 3, 2025 | 05:36 PM
hxmzh1's Avatar
W205 2020 C43 AMG
Okay will look at the user manual and get a trickle charger. Hopefully it will fix itself. Thanks for everything and lookout for pics lol
