C450/C43 AMG
C450 AMG 7G-Tronic Transmission Slam/Jerk 1-2 in Sport+ Only
Old Apr 6, 2026 | 05:28 PM
Alazwar's Avatar
C450
Hi
i have a 2016 mercedes c450 amg
I am experiencing a violent transmission shift that only occurs under heavy load / WOT (Wide Open Throttle).
1. From a Standstill: In Sport+ mode, when accelerating hard, there is a noticeable delay/hesitation followed by a violent jerk/slam during the 1-2 shift. It feels like a massive power-cut before the gear slams in. All other shifts are smooth.
2. Rolling Acceleration (Speed Bumps): The issue also occurs when slowing down for a speed bump; when the car downshifts to 1st gear and I accelerate hard again, the same 1-2 slam happens.
3. Sport Mode: The 1-2 shift is smooth, but there is a very slight delay during the 2-3 shift.
4. Comfort/Eco Modes: All shifts are flawless and smooth under any throttle input.
5. Light Throttle: No issues in any mode, including Sport+.
Question:
Since the transmission oil was clean and the mount is new, what could be causing this specific "1-2 Slam" in Sport+ during hard acceleration or after slowing down? Is it a TCU software/adaptation issue or related to engine torque management during shifts?
I would appreciate any insights!
Old Apr 6, 2026 | 07:30 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
are you serious...
Originally Posted by Alazwar
Hi
Question:
WOT TT slams 2nd gear...
This is tranny self-defense to work max output.
Valve body provides max pressure to work clutch.
Old Apr 6, 2026 | 09:21 PM
Alazwar's Avatar
C450
I appreciate the technical explanation about the valve body pressure. However, what makes me feel this isn't just 'firm shifting' is the noticeable hesitation/power-cut for a split second right before the slam occurs. It feels like the car is holding back or 'choking' before it violently engages 2nd gear.
Also, the fact that it happens even when re-accelerating after a speed bump makes the car very jerky and unpredictable in Sport+.
Do you think a TCU adaptation reset would help the transmission relearn the shift points, or could this be a boost management issue where the engine isn't bleeding off pressure fast enough during the shift?
Old Apr 6, 2026 | 10:22 PM
When up shifting the engine Rpm needs a drop to match new gear target Rpm.
This matching is actually done in well coordinated shifts.
Smart adaptive tranny learns its current adaptations from historical shifts. I don't believe you'll get improvements with re-adapting.
Old Apr 7, 2026 | 03:44 AM
Alazwar's Avatar
C450
Interesting point about the RPM coordination. If the matching isn't happening smoothly as you described, and given that you don't think re-adapting will help, could this point back to the engine side?
could a lazy Boost Control Solenoid or a vacuum leak be causing the engine to hold too much boost during the shift, preventing the RPM from dropping fast enough to match the next gear? This would explain why the TCU 'slams' the gear in to prevent clutch slip when it realizes the engine torque hasn't dropped as expected
Old Apr 7, 2026 | 12:39 PM
back to root
By pointing back at the engine... you understand where tranny issues are born!
Also the link between ECU + TCU is CAN-C to interconnect them. When that bus is busy the exact timings of coordination suffer. Network partners flood the bus through Gateway!
To that extent you want to :
Scan the whole chassis (any faults??)
Reboot whole chassis with a battery disconnect
CTEK main battery float up
Above steps will help restore engine/tranny predictability for a couple days at a time.
Old Apr 9, 2026 | 04:26 PM
Alazwar's Avatar
C450
Thanks for the detailed explanation about the ECU/TCU coordination.
I'm experiencing the exact shift lag and clunking issues you mentioned on my C450, but I also have a noticeable whining noise coming from the rear differential.
Could a worn-out rear diff (with excessive backlash/play) be causing these coordination issues? My theory is that the mechanical 'slack' in the driveline is confusing the TCU's torque-drop expectations, leading to that hesitation and the subsequent clunk.
Do you think addressing the diff whine/play would resolve the tranny predictability issues, or should I still focus on the electronics/network side?
Old Apr 9, 2026 | 06:35 PM
You do need to repair the rear diff input shaft bearings ASAP before it becomes a complete swap job.
The only way to prevent that damage by keeping clean diff oil.
I don't think the diff. slack participate to significantly confuse the tranny shifts.
The throttle hesistations are caused by lean fuel mixtures.
