amg question
1993 Mercedes 300e 4-matic (m103 motor)
amg question
I knwo the c63 e63 and s63 and all the other amg's will eb usuing the 6.3ltr motor however my question is what sthe power difference with the smae motor but different trim line.
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Your question is unclear. If I understand what you are asking, the 6.2 liter engine installed in the C, E and S classes is the same basic engine. Mercedes claims 507 hp in the E and S classes but have de-tuned it to 451 for the C. Most people here think that a simple ECU upgrade and larger airbox would bring the C's output back up over the 500ph mark.
Sure, some of it is marketing, but some of the lower output in the smaller cars is because headers and other plumbing are less efficient. This is partly because there isn't as much room for ideal routing (it's a lot of engine to shoehorn into a compact sedan) and partly to keep costs down. Aftermarket tuners will be able to narrow the HP gap, but it will take tubing, not just ECU changes.
MMM...maybe a bi-turbo C 63 amg by garret would be better
how many hp and n\m could it have? 650 hp and MMM..1100n\m??
obviously it'd better change the rear tireas for example put on it a 315\30 r 19...
0-60 mh in 3, 5 sec and max speeed...about 340 km\h
MMM MAYBE I'M DREAMING TOO MUCH but in the truth it couldn't be bad
2013 SL 550 (Previously 2012 Porsche Panamera Turbo-S, 2015 Tesla P85D, 2007 S600, 2005 E55 AMG)
You will need more than tires.. At these levels you are stretching what the current 7 speed transmission can take. (Why the V12's use the more robust 5-speed)
Chris
Chris
tire obviously biggggggger....i have never undestood why the 420 cdi engine mount the 7 g tronic and it have 700n\m of turque and the 55 amg kompressor who has the same turque do no use the 7 g but the 5 nag!! i can understand!!
