C63 AMG (W204) 2008 - 2015
Dyno Results - 2008 C63
Old 04-28-2008, 05:44 PM
E63PWR's Avatar
'05 C55
Hi everyone,
I took delivery of my car last night and had it on the dyno today. Ran it in 4th gear a couple of times and the numbers repeated themselves. Car has less than 100 miles on the odo.
Attached you'll find pics of the car, dyno results and a You Tube link to the video.
Car made 380.67 RWHP and 364.30 RWTQ on a Dynojet dyno.
Link to You Tube video:
http://www.youtube.com/watch?v=SNQtqpOY2zQ
Enjoy!
Attached Thumbnails Dyno Results - 2008 C63-c631.jpg   Dyno Results - 2008 C63-c632.jpg   Dyno Results - 2008 C63-c633.jpg   Dyno Results - 2008 C63-c634.jpg
Old 04-28-2008, 05:54 PM
RENNSTAGE's Avatar
put some more miles on that puppy and you'll be pushin alot more power
Old 04-28-2008, 05:57 PM
lauer87's Avatar
E550
Didnt your dealer tell you about the break in period? I believe the break in is very important on these 63 engines. Our dealer which has rebuilt and eventually replaced 2 different 63 engines (s63 and ML63) claimed they believe it was because the owners did not properly break them in( and they had reason to believe so). Idk call me crazy but i just dont think its good for your car
realsanaii's Avatar
2005.5 A4 2.0T
http://www.m3post.com/forums/showthread.php?t=137233
Above is the new M3 dyno with 100 octane fuel and it has gotten about 366rwhp for the comparison.
Old 04-28-2008, 05:58 PM
rutiger's Avatar
RS4/Jeep SRT8
right around 15% loss. seems pretty typical. be interesting if any gain is seen after break in.
Old 04-28-2008, 06:22 PM
///AMG4EVER's Avatar
CLS55 Designo 030
Congrats on the purchase E63PWR! The car looks amazing.
Where in town is that dynojet at?
You should consider around 17-18% loss.
Old 04-28-2008, 06:29 PM
E63PWR's Avatar
'05 C55
I removed the air filters and left the charcoal filters in place. It gained absolutely nothing. The air intake does not appear to be restrictive at all. I still want to figure out why my E63 made 410 RWHP stock and this car only does 380. Possibly in the tune but I need someone who can read the total advance ignition timing during a run. Done testing for now.
Old 04-28-2008, 06:30 PM
oldgixxer's Avatar
'05 C55(sold)'05 E55(sold)'06 911C4S(sold)'06 ML350 '06 CLS55(sold),buncha slo bikes
the 6.2l engines absolutely benefit from an extended break-in period.I noticed a marked difference once the car hit 5000mi compared to when I first got it.Everyone has their own theory as to which break-in procedure works best.
I have my own,and as with all my new engines I dumped the oil&filter at 800miles.Seemed to have worked as my car clearly traps 2-3mph higher then other 63's at the track on the same day
Old 04-28-2008, 06:34 PM
E63PWR's Avatar
'05 C55
My E63 not only produced a higher RWHP but it did feel slightly quicker than this car. That will hopefully change as everything breaks in.
Old 04-28-2008, 06:38 PM
E63PWR's Avatar
'05 C55
Thanks for the kudos. I always calculate an 18% drivetrain loss in all late model automatics. The dyno is at MTI on the west side of Houston. Saw an '06 Z06 make 900 RWHP there not long ago. Had an F1 Procharger on it and built 427. Guy drove it back to Arizona and got 27 MPG!
Old 04-28-2008, 06:41 PM
Derspeed's Avatar
X3 and 2012 C coming soon
Hell, the exhaust note alone made that clip worth it.
Old 04-28-2008, 06:43 PM
oldgixxer's Avatar
It seems as if your going to be the first one to get some good numbers from a C63,I'm really anxious to see how your car is w a few thou on the odometer.
Do you plan on taking it to the dragstrip?
Old 04-28-2008, 07:05 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
wow, the car sounds great, thanks for posting the results! you can pretty much see where the power levels off at 100MPH, ecu turning will turn this into 500+ HP, that HP curve will just keep rising....
do you have the dynojet run file? if so we can overlay it with an E63 to compare, PM me.......
Old 04-28-2008, 07:08 PM
kindafast's Avatar
W210 E55 & W204 C63
hah... with C63 being dynoed with less than 100miles on the odometer, I won't doubt the next E92 M3 killing C63 story.
Old 04-28-2008, 07:13 PM
E63PWR's Avatar
'05 C55
I could read the ignition timing on my E63 using an MSD Dashawk but it doesn't work on the C63. The total advance I witnessed on the E63 was 22 degrees. I'm curious where AMG set the timing on this car. I'll take it to the track to see how it does. I think the car is a little deceptive in the sense it is quicker than it feels.
Old 04-28-2008, 07:15 PM
oldgixxer's Avatar
maybe tranny ratio's/rear end gearing?
Old 04-28-2008, 07:35 PM
Vadim @ FD's Avatar
S600TT, R350
You got it backwards. Remove charcoal, leave stock filters alone.
Stock E63s run about 22 degrees, CLK63 is down to 17-18, I would not be surprised if C63s run below that.
As far as break-in. The harder you run from the beginning the better it will be.
Old 04-28-2008, 08:34 PM
TopspeedINC's Avatar
the ladies crazy
Sweet, considering that it made 380whp with an SAE .97 correction. That means it made 391whp with no correction factor.
Take 391 and figure a 15% drivetrain loss puts the crank power right at 450hp
Old 04-28-2008, 08:43 PM
BoBcanada's Avatar
AMG
how do you like the car overall? Compare it to your E63? Would be great to hear.
Old 04-28-2008, 09:28 PM
kimiFan's Avatar
As far as break-in. The harder you run from the beginning the better it will be.[/QUOTE]
Hey just curious, is your suggestion to run the car a little harder from the get go, as opposed to babying it for the first 1000 miles. And if so? would you elaborate a little more on your theory, & why you think this is better? Thanks, I'm very interested to hear your reply, Cheers!
E63PWR's Avatar
'05 C55
Hi Vadim,
I'll pull the charcoal filters and dyno with just the factory air filters in place and list my results. Are you able to have the C63 PCM modded yet?
Your break-in procedure is exactly the same as mine has always been. Drive it hard from the start and it will typically perform better than those that are "babied" from the beginning.
Old 04-28-2008, 09:36 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Just my two cents, but my first MOD on my C55 was to remove that "Break-in" window sticker!!
Mercedes and AMG program the ECU to be very forgiving with high tolerence for average drivers. ie: a non enthusiast that might not follow service schedules, might use low grade fuel and otherwise not take good care of the vehicle. This is why companies like Kleemann and Renntech can squeeze extra HP by chipping alone.
This also relates to the easy break-in outlined in the user manual. this breaks in the motor in a way that if the service schedule is not followed, poor grade fuel used or general abuse, there are pre existing tolerences in place to protect the motor.
"Spare the rod and spoil the child"
If you are an enthusiast, drive as you would normally right from the start. The first 40 Klm are the most important. Hard, steady acceleration in second and third gears to a high rev (5 to 6K RPM repeatedly) is critical to seat the piston rings solidly.
It is VERY important to let the engine warm to full operating temp and then run the first few minutes at moderate loads as to let the tranny fluid temp to catch up as well. The tranny needs to seat and seal over the first 1000 miles/1600 km. This will produce a smooth, responsive and very tight engine that will stay that way. Still follow the recommended scheduled first oil/filter change and away you go.....
I'm not saying to go racing the first weekend but if you drive hard and smoothly through the gears right out of the gate you can expect to maintain top torque and HP numbers for the life of the engine. Follow the "recommended" break in and expect a 10 to 15 HP drop and for sure, lots of "cylinder blow by" in the years to come.
I have been breaking in engines (both high performance and stock) this way for years and its never let me down.
Old 04-28-2008, 09:46 PM
E63PWR's Avatar
'05 C55
I've only driven the car a short distance so I can't tell you that much. I can tell you that the seats are great no matter what other people are saying about them but I'm only 5'11" and 160 lbs. The one piece seat is a little tall so if you try and look over your left shoulder, you see nothing but headrest. Comparing the C63 to my C55 was a little shocking at best. Jumping in the C63 immediately made the C55 seem like an antique and dated where I never felt that way about that car before. Reading what magazines and others were saying, I thought for sure the C63 would ride rougher than my C55. That is wrong! The C55 is harsher on dips and bumps in the road than the C63. The C63 is by far no plush ride but I can easily deal with it on a daily basis on the crappy Houston streets.
The E63 definitely seems a little quicker although the magazines say the C63 is just as fast or faster. You never know if the magazine test car was "tweaked" either. Only independent drag strip testing will prove that. The E63 was a great car but lacked the steering response, handling and improved braking feel the C63 exhibits. The E63 wins hands down if you're looking for a great smooth ride and all the power.
Personally, I would not go back to the E63 after getting exactly what I wanted in the C63. A serious performance 4-door sport sedan with very aggressive looks, extremely modern interior (with a REAL NAV system - FINALLY!!), and upgradable performance (hopefully soon).
If you have any questions about the car, I'll be happy to give you my opinion on it as I've had a few other AMG's to compare it to. 2 C55's (310 RWHP), an E55 (457 RWHP), an E63 (412 RWHP) and now the C63 at 380 RWHP.
Old 04-28-2008, 09:47 PM
kimiFan's Avatar
Hey thanks Barry, very informative!
Old 04-28-2008, 09:48 PM
E63PWR's Avatar
'05 C55
+1 AMEN!
Quick Reply: Dyno Results - 2008 C63
