C63 AMG (W204) 2008 - 2015
Recent malfunctions/maintenance for your C63
Old Jul 16, 2008 | 11:32 AM
shadowskill's Avatar
2008 C 63 AMG (palladium Silver); 2018 E400 4matic Coupe (Pearl White)
I do not know if i'm the first to have one, but since i do, i'll post it here.
3 days ago i found out that oil was dripping from the left bottom side of the front bumper. After close examination it seemed that the oil intercooler connected to the bumber on the left bottom side was causing the leak. I took it to the dealer next morning and today they told me that the O-ring connecting the tubing from the oil cooler (oil injector it seems) was damaged, without really knowing why.... Mind you the car only has 2000 km on it and something like this pops up.. kinda worrying..
If any of you guys have similar early malfunctions or issues, share it with us here.
Old Jul 16, 2008 | 12:25 PM
MNL ICE's Avatar
08 C63 AMG
mine is oil leak less than 2k..they fixed it after 2 weeks oil leak again so i brought it again and they said oil pan is deformed ( factory defect) and they replaced it and after 2 weeks oil leak again..so far i havent brought it again coz im busy ..
and last one is my moon roof malfunctioned.
Old Jul 16, 2008 | 12:38 PM
Man i hear that there is more than one case with the oil leak already.. there might be a defect in your engine causing abnormal oil pressures. check on that. this is definately not good.
Old Jul 16, 2008 | 02:15 PM
Hans Delbruck's Avatar
What I like!
No leaks here... just checked under the car to make sure!
I had a bad cam position sensor at 60 miles.
I'm now at 2000 miles with no other problems.
Old Jul 16, 2008 | 02:16 PM
Glock Guru's Avatar
Steel Gray 09' C63 AMG
I sure hope this is just first year production blues. I for one expect top quality from a car of this level and will not stand for something as easy as an oil leak.
-Troy
Old Jul 16, 2008 | 02:59 PM
B.E.R.U.A.N.G's Avatar
CLK 500(Gone), C63 FTW!
I dont think C63 got an Intercooler though...
Old Jul 16, 2008 | 03:57 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
The oil leak, the O-ring, and the cam position sensor have actually been very common issues since the 63 engine was released 2 years ago, but they're very minor. There are a couple of TSBs out for each of those things, and the dealer should be able to fix them in a couple of hours.
Old Jul 16, 2008 | 04:02 PM
scm319's Avatar
2003 M3
It's an "oil cooler" my friends, not an intercooler or oil intercooler...
Old Jul 16, 2008 | 04:41 PM
Glock Guru's Avatar
Anybody have connections with MBUSA to post the TSB's on the site? Would be nice to have a source for TSB's and recalls on the C63 other than your "friendly neighborhood dealer".
-Troy
Old Jul 16, 2008 | 07:18 PM
MB_Forever's Avatar
-Troy
They're here somewhere, I'll try to find the link for them. But for some reason, I don't think it'll matter much because the dealer will not apply a TSB unless there is a problem with the car and you actually complain about it. Sometimes, it may take a couple of complaints before they actually do it.
Old Jul 16, 2008 | 10:43 PM
OLDSCHOOLRICE's Avatar
07' E350, 71' DATSUN 510
There is also a new TSB for the sunroof issue on the 204 chassis. The repair is a new software flash.
Old Jul 16, 2008 | 10:48 PM
Glock Guru's Avatar
Thanks, something is better than nothing.
Old Jul 21, 2008 | 06:58 PM
ARC101's Avatar
2008 C63
I too have had the moon roof issue. It did not auto open close and was moving one position at a time. Also at random when the automatic mirrors open back up (just after the door is open and I'm starting the car) I hear a wierd humm form the drivers side. Consumed 1.5 quarts of oil at about 2,500 miles but that should be with in spec.
Old Jul 21, 2008 | 07:48 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Definitely not at the same level as an oil leak but wait until someone tries to unlock your back doors by pulling the lock pin. Don't try it- they pull right off and do not go back on. 2-3 hrs labor to repair and they don't have a fix for the defective part. The dealership super-glued mine without my knowledge and they were surprised when I noticed the "acetone" burn on the pin and surround.
Old Jul 21, 2008 | 08:21 PM
Glock Guru's Avatar
1.5 qt. of oil consumed in 2500 miles, what does that thing have a old school rotary 12A engine?
Old Sep 21, 2008 | 05:23 PM
Whiplash's Avatar
C63
Just dropped mine off at the dealership for an oil leak too. Noticed it at 500 miles. It's coming from the pan and I noticed oil at the cooler too. The dealership is being very good about it. They were almost as upset about it as I was. We'll see when I get it back.
