Weight of C63 wheels
C63
Hi !
Hello to everyone, I'm new here.
Do anyone know what is the weight of C63 18" wheel (with tire) and weight of optional 19" ?
1 Post
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
Or weight without tires of 18" stock wheels?? Been looking everywhere for that info.
A lot of people buying lighter wheels but how can you tell when you don't know the original weight?
Please post if you know!
Thanks =)
Thanks =)
I can tell u that a clk500 17in 7.5 is 25.1 with no tire I will b doing a 17in 8.5 in about a week when I take the tire off 2 show u that
but hope that helps
but hope that helps
1 Post
So what do you say? Between 25 and 27 considering they are possibly lighter thank you 17" (but also bigger)? If anyone has an exact number or one of these wheels hanging around that would be very useful!
For me, lighter wheels is one the best modification you can do to a car. It improves mileage, acceleration and braking response.
On my current car I went from 20lbs 17" to 10lbs 15". Night an day. Literrally dropped half a second on the 1/4 mile between the 2. But then my car didn't have 400 pounds of torque. I don't know if it makes as much of a difference at this level with that much power (or maybe more, no idea). Guess we need an engineer.
thanks!
thanks!
2009 C63 AMG
Rear stock 18 inch rim is exactly 25 lbs. I just measured my spare in my garage.
Usually reduction of below suspention is said its same as 6 times of weight reduction above suspention. It is that important to get light wheels. You really can feel it. Like Chief63 said you can cut on time on all kinds of things. The car well fell quick, handle great, stop great, etc you really can good things.
1 Post
Thanks for the precious info I'm sure this will be useful for many others.
If we do a little math, rear wheels are 9.0in X 18 and front are 8.5in X 18.
So between the 2, the rear wheels are 5.88% bigger so front wheel wheight should be 23.5 pounds (23.53 exactly).
So here are full wheel specs for the stock 18 inch rims that I have so far:
Front: 235/40R18 with 8.5x18 wheel with 45mm offset 23.5 pounds
Rear : 255/35R18 with 9.0x18 wheel with 54mm offset 25.0 pounds
Bolt pattern: 5 x 112 mm
Take care.
chief63
