C63 AMG (W204) 2008 - 2015
Nitrous Oxide Systems (NOS)
Old Aug 16, 2014 | 11:58 PM
  #51
mthis's Avatar
Anything W/4Wheels
Originally Posted by Merc63
200 shot damn, ur tranny not gonna last long.
Will see how the 75 shot goes. I have a trans cooler that's going to get installed soon so that will help with temps. For the 200 shot I will have to get the weistec trans.
Old Aug 17, 2014 | 04:41 PM
  #52
mthis's Avatar
Anything W/4Wheels
Old Aug 17, 2014 | 05:26 PM
  #53
Heath T's Avatar
C63 AMG
Where is the nozzle mounted?
Old Aug 17, 2014 | 05:36 PM
  #54
Merc63's Avatar
C63 AMG
Are u gonna hammer down at the track this fall?
Old Aug 17, 2014 | 07:30 PM
  #55
mr747's Avatar
c63
Originally Posted by mthis
looking good mate :0
Old Aug 17, 2014 | 10:21 PM
  #56
mthis's Avatar
Anything W/4Wheels
Behind the air boxes can't see them under the hood. And the switch is in the dash that turn the nos and bottle warmer on.
Old Aug 17, 2014 | 10:25 PM
  #57
mthis's Avatar
Anything W/4Wheels
Going to try . Full interior tho I'm tired of taking the seat out . They in for good now.
  #58
mthis's Avatar
Anything W/4Wheels
Thank you. Just trying to go fast .
Old Aug 17, 2014 | 10:44 PM
  #59
mr747's Avatar
c63
do you have a link to how to take the seats out??
Old Aug 17, 2014 | 10:53 PM
  #60
mthis's Avatar
Anything W/4Wheels
Never did a DIY but it's very easy. I can walk you thru if you like .
Old Aug 17, 2014 | 10:57 PM
  #61
mr747's Avatar
c63
ill pm you
Old Sep 24, 2015 | 04:29 PM
  #62
Getii2012's Avatar
Cls55
This is my set up i spray 75 shot n the car loves it <br/>
Old Sep 25, 2015 | 12:35 PM
  #63
HardC63's Avatar
C63 AMG
I love it! When done right, NOS is one of the best mods (bang for buck) there is.
I have found that folks who talk crap about NOS don't have a freaking clue and only talk based on ignorance.
I had NOS in many applications and NEVER EVER had any issues...NEVER!!!
Old Sep 26, 2015 | 10:05 PM
  #64
Getii2012's Avatar
Cls55
Thx man I love the feeling of nos n in stl not 1 mercedes with spray lol
Old Mar 1, 2017 | 02:16 AM
  #65
727E63AMG's Avatar
2014 E63 S, 2017 GLE 43, 2020 Cadilac Escalade, 2019 Lamborghini Performante
Originally Posted by TA-9FF
+1
I'm always amazed at Euro drivers thinking they have Civic's........
Might as well get a 5' spoiler and obnoxious eBay bodykits.
For the NOS Merc drivers, let us know when you blow your engines.
Nitrous started to be used in EUROPE so I don't understand your "Euro drivers thinking they have Civics" comment.
I'd suggest you read up on nitrous before making assumptions based on TV movies lol
PS:
Look up what Luftwaffe and British airplanes were using during WW2
Old Mar 1, 2017 | 10:01 AM
  #66
Mbm6f's Avatar
09 C63 AMG
Back from the dead.
I don't mind it.
Some awesome stuff in this thread.
Old Mar 1, 2017 | 03:58 PM
  #67
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
My Opel runs nitrous. T61 turbo with a 160hp nitrous shot on a 2L 16 valve Opel motor.
Old Sep 23, 2018 | 02:54 PM
  #68
Peterc63's Avatar
C63
I had Nitrous in my first c63. Was running stage 2 header file from OETUNING. No nitrous file. Ran a 75 shot with stand alone fuel cell filled with c16. Had a progressive controller for it. Setup was a little more on the expensive side but I never half *** anything. If done right you can get 560+whp and HUGE jump in torque for under 2k... that’s a ton bang for your buck considering blowers cost 4x the amount lol and add a ton of heat soak. The only issue I have with it is... the constant monitoring and making sure everything is 100%.
Old Sep 24, 2018 | 05:09 AM
  #69
Celicasaur's Avatar
W212 - E63 AMG
What were you doing with regards to the constant monitoring? Leakdown tests? Compression tests?
Sounds like you had a nice set up. TBH if you're running that kinda hit on such a big motor with 8 cylinders and you're also using a fuel cell, I wouldn't worry much at all about monitoring after you've completed some initial testing to ensure all is well.
If it makes you feel better, I run nitrous on my built Celica motor, running a static compression ratio of over 14.5:1, on pump fuel and a very aggressive tune. However I only use a small 60hp hit....15hp direct-port into 4 cylinders.
Old Sep 24, 2018 | 05:31 AM
  #70
Peterc63's Avatar
C63
Just the parinioa of the bottle pressure not being exact, solenoid not working 100%, nozzles clogged, fuel cell pump not working... just so much to think about. I wasn’t worried about the motor or trans.. I had my NX controller properly setup with afr parameters set, nitrous being cut at 6800rpms to save the clutch packs..etc. I knew the timing advance on Jeremy tune and what Afr we were targeting for 93 and it was smooth and clean for a 75 shot with c16. Yeah my setup wasn’t cheap. And I was putting out 560 rwhp on such a small shot... the torque was amazing under the curve lol. I think Nitrous is a great tool when done right. I certainly prefer it over Weistec Stage 1/2 kits. But this time around I’ll most likely be doing an ESS kit or Magnuson. I just want to set it and forgot it and not mix fuel in my trunk or worry about the whole nitrous system in general or just refilling bottles. **** gets expensive after a night of 40 rolls lol
Old Sep 24, 2018 | 05:37 AM
  #71
Celicasaur's Avatar
W212 - E63 AMG
Haha, yes it can certainly get expensive if you use it regularly. For racing it's fine, because the benefits in fuel economy when running NA will be better than full-time FI.
Also, it is possible to have a system set up so that if the fuel solenoid doesn't fire (for whatever reason), the nitrous solenoid won't fire either. I used to have that on my car, but when I took it apart one time, I forgot how it was meant to be rigged up again.
Be sure to do a review of your SC set up vs Nitrous....it'll be interesting to read.
