Repeated engine oil light
08 C63 AMG, 09 Range Rover Sport Supercharged, 09 Audi A8L, 09 Ferrari California, 08 S Class
Every few days i've been getting the "check engine oil level when next refuelling" message on the dash. Went and bought the recommended engine oil and topped up until the dipstick reads exactly half way.
Got the same message again but the oils not low.. Anyone had this before?
2008 C350 Special Edition
I've have an 08 C350 but I've been getting this error was well. My dipstick was showing a little over the minimum after a 30 minute drive so it might just be a tad low. I am going to add a little after I get home to see if it goes away, but I'll post here if it doesn't.
Only 5k miles on my car, so I am not sure why it is so low already.
I have had this happen to an E350 as well.
Just check the oil level and add a quart or two of oil when it needs it. Get your dearership to give you 2 quarts to carry around in the trunk.
Its normal for this motor to eat oil so dont worry that you have a bad motor. The harder you drive the more it will eat oil also.
Enjoy the little beast.
"the harder you drive it the more oil it will eat"
Ah ok i see. Well, that would probably explain it. I've been a naughty boy.
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
If it is only filled halfway up the dipstick, I wouldn't be surprised to get the add oil light. You might just need to add more.
FWIW I haven't had any oil consumption at 3000 miles now. Then again, my opportunities to open it up are rare, but I do try....
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
There is a TSB for this motor says consumption is normal and another saying that loud tappets are also normal.
I checked the S63 before leaving for a road trip and it had zero oil consumption in lat 1k miles. Before it would be almost a quart low already. Its finally broken in and seated.
My E350 used to puke blue smoke on a warm start up (when it sat for say 15 minutes) but the minute it hit 10k miles it all went away. MB has a TSB for the 350 motor saying have the tech drive the hell out of the car at high rpm to resolve oil consumption and blue smoke issues. It just needs to be broken in.
1 Post
2011 GLK350, 2010 ML350, 2008 C63 AMG
So I went out to check out the oil dipstick and got confused with the readings. So the dipstick has 3 red plastic marks. Can someone help me identify which one is the upper and lower mark?
My oil after 1800 miles was above the bottom red plastic mark. So does that mean according to the manual that I should add a quarter of oil? I have never see the oil engine light turn on though.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
[edit: deleted my other question]
I realized I was repeating myself.
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
All engines burn oil, newer engines burn fuel much cleaner than before so the oil doesn't get "topped up" as much by contaminants.
Also remember that the 63 engine is a large bore engine with low tension piston rings and very short piston skirt. This combined with large piston oil squirters spraying oil directly at the base of the piston and Mobil1 0w-40 makes for a much higher rate of oil consumption than your average engine.
I would be VERY surprised if you DIDN'T need to top the oil up every 3000mi/5000km
2008 CLK 350, 2005 Chrysler Crossfire Roadster
There could still be a fualt with the oil level sensor, coding in the instrument clustor or the incorrcet dipstick has been fitted.
If you oil level is correct on the dipstick and you're still getting the warning message then it's time to go back to the dealer
