DoDo Juice Review & Detail - C63
I used some of the left over Adam's car wash I had in my Foam Cannon to help let the car soak. Fall has already started to come fast here in NY with rain. After allowing the car to soak a little, I started to let the P21S cleaner get to work on the wheels. 5 minutes later with mild aggitation...the dirt was literally rolling off. I then started to wash the car with the Perls soap which is very mild...but the adam's pre soak helped a lot to remove the dirt. Once the car was washed, I then broke out the Wolfgang clay lube and clay and began running around the car lubing and claying. Not much contaminants and dirt as you can imagine for it being a new car. Most of the dirt and particles was from the front/rear bumpers and fenders. After the clay, I set up a new bucket with some Duragloss 901 soap and began washing down the car. Amazing, car looked great after the clay and wash...and still had some softness to the touch. I then used a foam applicator and started to use the DoDo Lime Pre Wax which went on easy and came off just as easy. The hardest part I had on the day, was not enough consistent light to see where I had completely applied the wax. I did literally half the car and went back to remove it with a micro-fiber which seemed to work out fine. The car did look and feel great with just the Pre-Wax. Now the fun part...I opened the Light Fantastic Wax and ooooh baby it smelled great. Was a little hard at first..but once I started getting my fingers in there..it loosened up ( no pun intended :lol ) I literally put some of the wax in my hand, and massaged it into the paint on the car. I did the entire car in 1 shot which took about 20 minutes. 2 Microfiber towels and a buffing towel got the wax off just right. To finish it off, I used some FK425 to wipe the car down for anything I missed.
The wheels, yikes...Very dirty and a lot of spokes. The P21S did a good job of getting 80% of all the dirt off, but I still went back and washed it with a microfiber mitt and duragloss soap. A quick rinse and dry was all it took. I then applied the Armor All Tire Gel which is great for the money. I tried to use my Swissvax Autobahn wheel wax, but it is very difficult to use. Small container and doesn't go on as easy as I would like. SO, I just used my Opti-Seal. Great product.
All in all, I must say that the DoDo products are amazing. Just 1 coat of the wax was all it took to get the depth and wetness look in the paint. The Clay along with the Pre-Wax got all the little dirt marks/specs off the paint. I very happy the way the things came out. I think for the next couple of weeks, I will use the Opti-Seal until I give the car another wax. At $70 a container for wax, I can wait a little.
Sorry for the bad pics and long write-up. I didn't take too many before or during pictures, but you can see the dirt..after is what counts :clap:
Thanks to George from DI for hooking me up with the DoDo and advice.
Wash & Dry
Adam's Car Wash/Einszett Perls (used with foam cannon, had some extra adams to use to help let the car soak) then I scrubbed it with the Perls which is very mild.
Duragloss 901 - was used after the claying.
Jumbo Waffle Weave Microfiber
Wheels and Tires
P21S Wheel Cleaner
Swissvax Wheel Brush
E-Z Detail Brush
Opti-Seal
FK425
Armor All Tire Gel
Exhaust
Mother's Mag & Aluminum Polish
FK425
Clay
Wolfgang Elastic Poly Clay
Wolfgang Clay Lubricant
16x16 Cobra Microfiber Towel
Glass
Stoner's Invisible Glass
FK425
Pre-Wax & Wax
DoDo Lime Price Pre Wax Cleanser
DoDo Light Fantastic Soft Wax
FK425
sadness
I've put dodo juice on my car when I first got it (about a month ago) and found it vary hard to use....
Application was difficult and polishing off was very hard work. Still it washes real easily now.....
I used this one...
http://www.theultimatefinish.co.uk/S...?ProductId=406
M
I used this one...
M
I can not decide if go DoDo or Zaino
If I do Zaino:
Zaino Z-AIO All-in-one
Zaino Z-CS Clear Seal
Zaino Z-8 Grand Finale Spray Seal
If DoDo:
1. Dodo Juice Lime Prime
2. Dodo Juice Purple Haze
