headlight problem
the 1st pic is with regular lights
the 2nd is with highbeams
Hope this helps.
thanks for your info ill be sure to let mb know next time i go.
(customer states headlight are pointed down too far)
tested lamp. confirmed complaint. star tested. found code for left front level senson line faulty or shorted. check senson pin 5 for power and ground. pin 1 grounf ok. power failed. electrical tested resistance in wire from pin 5 to pin 3 in front sam. failed.
stated to trace wire. open part of harness. found broken wire due to zip tie. repaied. erased codes. tested. passed.
aligned lamps with sds. pass.
i cant drive my car in place wher ther is no street light with out the highbeams. and then i get people on the other side blinding me.
oh yea i almost hit a dear in P.A
