Transmission operation
I figured out that the tranny in M mode is pretty useless and I dont think fast enough to make it work the way it should.
SO in sport I have found out how to make it work!!! Remove it from Park to Drive and it will upshift and downshift through all the gears. If you down shift to a gear say 3rd into a corner. If you leave it in 3 it will shift down to 1st at the stop. Then as you leave it will shift automatically up to 3 and hold 3 till you up shift. If you down shift to 2 and then pull away from a stop it will shift up to 2 and hold 2 till you upshift.
does that make sense? I think its thats the way it works. I THINK if you down shift to 1 and then leave the stop it will upshift to 2 and hold 2 till you shift to save the motor I think. I havent verified that but I will know tomorrow. I think its a pretty convenient way to work the tranny. I cant find a way to make the tranny work in manual mode that is more fun than the Sport mode
You sound really aggravated..
When you pull the paddle in an automatic mode, the car goes into say "D5" if you pulled the paddle to downshift to 5th, or "D4" if you downshifted to 4th. It just means you're still in an auto mode, but the car won't shift beyond that particular gear (3rd if in you're in D3, and so on..) You can see which "D" you're in, in the gauges.I use my right foot as the gear selector. Go past kickdown, get max gears and power. 3/4 throttle, it will usually downshift 3 gears. Half throttle, it will usually downshift 2 gears, light throttle, it will downshift one gear. This seems to be the most efficient for me
