C63 AMG (W204) 2008 - 2015
I think I screwed my C63, please help
Old 12-15-2008, 01:05 PM
davey0808's Avatar
c63 amg
I bought my C63 for 3 weeks and it is taken back to the Mercedes workshop. On the first day I took the car I asked the sales rep. that did it need run in for the first 1000 km and he said there's no need to. So I accelerated hard, used the manual mode and had fun with it. Until now (around 950 km) I heard that the engine was making some weird noise and it's like not lubricated well.
Guys is it serious? what are the worst things could be?
Many many thanks
Old 12-15-2008, 01:37 PM
bigbodybeeenz's Avatar
bike
most likely your car will explode within the next 2 hours
Old 12-15-2008, 01:41 PM
DerekACS's Avatar
2015 E250 BT 4M
It sure sounds like you ignored the "Breaking In" instructions contained in the C63 Owner's Manual and summarized on the driver's side window "AMG" sticker.
If your engine problems are related to driver abuse (failing to follow proper "break in"), you might be on your own for the cost of repairs. Don't forget your car has a "black box" memory that can inform the dealer's technician of maximum engine speeds and road speeds attained by your car. This information could be used to deny warranty coverage for your engine.
Old 12-15-2008, 01:53 PM
bike
Originally Posted by DerekACS
Don't forget your car has a "black box" memory that can inform the dealer's technician of maximum engine speeds and road speeds attained by your car. .
Wrong.
Old 12-15-2008, 01:57 PM
shap07s550's Avatar
'13 E63, '15 GL450, '12 Range Rover Sport
Been driving my C63 for a week and have been keeping it under 90mph like the rep said BUT I have been making fast starts from lights, gunning it for a few seconds to go from 0-40 or 0 to 60...is that ok?? I don't want to hear tha "weird noise" in my engine too...
Old 12-15-2008, 02:00 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Don't worry about it. It will get fixed under warranty and you will be beck on the road before you know it.
Keep us posted..
Old 12-15-2008, 02:11 PM
mrtesting's Avatar
09' C63 AMG (Gisele)
Many many thanks
Hand built engine.. they are meant to make noise for the first 1000 or so KMs.
Old 12-15-2008, 02:43 PM
Jae Duk's Avatar
'09 C63
should be ok...cuz i did it too
to break in your car you're suppose to keep the rpm constantly moving anyways
Old 12-15-2008, 03:04 PM
lee7758's Avatar
Porsche 911 Carerra 4S
That's ok man ! I think the warranty will still cover your car! Cheers up!!!
Old 12-15-2008, 04:17 PM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
I think the break in period is for the tranny only and not the powerplant.
Old 12-15-2008, 04:22 PM
passcheco
Guest
Posts: n/a
Many many thanks
STEP WAY FROM CAR.........HANDS BEHIND YOU BACK you shoud not drive PERIOD...........so you got screwed more then once. Don't you know car sales people by now? THEY LIE LIE LIE
Trade the puppy in you are done. Everything needs brake in even you bicycle. You would be so lucky if nothing happened, however if did your warranty maybe shot.
Old 12-15-2008, 04:25 PM
AMGTTV8's Avatar
AMG
what? did you just do some crack?
Old 12-15-2008, 04:26 PM
Merc-Skycap's Avatar
AMG & RR
Well your sales rep was stupid to tell u that. Anytime you buy a car you should check the manual, skim through it a bit.
Don't worry its a Mercedes not a BMW, u'll be fine as soon as its checked out but I would suggest going easy for some time. Have fun up to 80MPH and then once you have abt 1,500 ot 2,000 miles on it, you can start giving it some of ur heavy foot lol.
Drive Safely!
Old 12-15-2008, 04:42 PM
passcheco
Guest
Posts: n/a
Not today But really who drives a new car ***** to the walls without break in please
Old 12-15-2008, 04:51 PM
vb26's Avatar
Velvet Fleetwood
this has been an ongoing debate for a while, just do a search. some say there is no "break in" needed, others claim break in should be for the first few k.
Old 12-15-2008, 05:40 PM
wuyichao's Avatar
C63
i redlined my car the first day i took delivery.
i did this to my previous G35 too, and i never had a single engine problem
the people i know baby their cars, their cars arent doing well...
so its very controversial, but i prefer to push my car to the limit once a while
Old 12-15-2008, 05:42 PM
wuyichao's Avatar
C63
and to op
your c63 is fine, whatever happens, even the engine blows, it will be covered under warranty
Old 12-15-2008, 05:51 PM
ATL_MB's Avatar
2010 C63
Poster #10 is correct - the break-in period is for the transmission and rear-end, not the engine. The engine is run hard at the factory before being installed.
That doesn't mean transmissions are cheap, however. Change the fluids regularly (in both the trans and rear-end), and you will likely have nothing to worry about.
Old 12-15-2008, 09:16 PM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Maybe your engine is pinging - because you are not using right octane fuel perhaps, this is a common cause of pinging in engines, especially AMGs (if indeed that is the noise you are referring too).
Pinging has happened to my ML63 but can be caused by other things (however, the first question the techheads asked me was am i using the right octane fuel). I was using the right octane but when the the guys hooked car up to computer that saw that the ignition timing was not right for some unknown reason and they redid the software and drives like a dream. What noise is your car making? In my ML it sounded almost like a tin full stones was rattling round in the engine, especially in the 1-3k RPM range going up hills after the engine had warmed up.
Old 12-15-2008, 09:46 PM
B.E.R.U.A.N.G's Avatar
CLK 500(Gone), C63 FTW!
I didn follow the break-in period instruction, I drove it like I steal it since the very first day. I even raced mine with my friend E55 the very first night on around 50 Miles on the clock. Hit the speed limiter couple of time, and it's still running until now...except I need to top of the oil every month
BUT, I do warm the engine every single drive, at least up to 100F , then I drove it out of my garage, and do less than 4k RPM until the engine temp stop blinking (around 177F if I am not wrong)
you should be fine, my first service I was worried the "black box" will tell the dealer how I drove, but my dealer didnt even bother to asked me anything about that
Old 12-15-2008, 10:22 PM
paulGT3's Avatar
AMG C63
I dont think the German cars black boxes record driver history because of a philosophical difference. Even though we kinda look at Europe as socialistic, they do hold personal privacy pretty close.
Old 12-15-2008, 10:37 PM
norb's Avatar
2009 C63 AMG
Porsche has black boxes. It saves data anytime you go past the rev limiter and for how long. And I wouldn't believe any internet chat room advice on engine break in. Just follow the advice from the people, you know, who actually built your car.
Old 12-15-2008, 11:43 PM
JohnnyE63's Avatar
Same thing happened to me, I never knew there was a break in so i drove it like i stoll it. I had floored it at least 20 times the first day that i got it to impress friends, then the next day i hit 150 mph on the highway. 600 miles later i decided to read the sticker on the top left corner of the windshield cause i really didnt have anything to do and it said to drive like a old lady for the first 1000 miles. Now the engine makes knocking noise and the transmission also makes clunking noise when shifting. So 8 months later i figure that i should trade this abused e63 in and hope the dealer wouldnt hear all the noise my engine and trany was making.
You should do what i did and trade that abused car in.
Old 12-16-2008, 04:27 AM
GMW
GMW's Avatar
2013 ML63 AMG PP
The break-in period is mainly for the gearbox and drive train. Even with some little break in mileage for the brakes too. I was told this be a MB Tech who works on AMG models.
Driving like a bat out of hell from 0 and then continuosly driving like you are on maximum attack level, is not necessarily a good idea if you plan on keeping you car for a long time.
Old 12-16-2008, 06:35 AM
davey0808's Avatar
c63 amg
First of all thank you all for the comments, yes it is definitely from the V8 engine and it sounds like some small stones went into the engine and made some rattling noise. but of coz it just sounds like it.
Quick Reply: I think I screwed my C63, please help
