C63 AMG (W204) 2008 - 2015
Sumitomo 275/35/18 Rear Tire Replacement
Old Jan 2, 2009 | 03:04 PM
OverBudget's Avatar
2009 C63 AMG
So after seeing several posts saying 275's should fit, I stepped out in faith and upgraded the 265's I bought to 275's.
The Sumitomo HR III XL's were $179.99 each and will be here on next Tuesday. I will update after they are installed.
If they don't fit, I will be pissed.
Old Jan 2, 2009 | 03:59 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
No worries, they will fit.
I hope they work out for you. I am interested to see how you find the mismatch set of of UHP tires run. I always felt that UHP and Snows were installed with the same premiss.. Mount in full sets of 4 for best performance
Old Jan 2, 2009 | 11:57 PM
mthis's Avatar
Anything W/4Wheels
If for some reason they don't fit witch won't happen. I'll buy them from u
Old Jan 3, 2009 | 01:19 AM
paulGT3's Avatar
AMG C63
on a high performance car you should never run mismatched tires.
On a 62 Ford pickup not so bad. But an 09 AMG?
You should let the rears wear out, then repurchase the same rears. The OEM fronts will wear out with the 2nd set of rear OEMS then replace the whole set at once.
Old Jan 3, 2009 | 09:50 AM
v0ac's Avatar
C43 AMG & E55 AMG
Very true, just on my c43 I spend around 600$-700$ for rear tires every summer.
You can afford a c63 but cant afford good tires???
Old Jan 3, 2009 | 03:04 PM
MNL ICE's Avatar
08 C63 AMG
believe me he can afford tires, that's why he is called OVERBUDGET , he just wants to see if these new tires will last longer and he just want wider tires.
Old Jan 3, 2009 | 05:13 PM
OverBudget's Avatar
2009 C63 AMG
Thanks MNL ICE. Would it be ideal to buy stock replacements to match the fronts? Sure. Could I afford it? Sure. Will I notice a difference with the mismatched tires if I am just daily driving and going hard in a straight line? I doubt it.
if I don't like how it handles, I'll just buy tires to make them all match up.
Old Jan 3, 2009 | 11:49 PM
liquiddi's Avatar
2009 E63 AMG
There is not that much size differance in the 265 to the 275. You will be fine. Now if you tried a 285 or 295 you would have some problems. When I replace my rears I will be putting 275's on as well. I have always gone up a size with all of my cars. Almost every guy on the Jeep SRT8 forum has gone up at least one size on the rears on the stock rim.
Old Jan 4, 2009 | 12:38 AM
SebringSilver's Avatar
R8
What about 275s on 19" wheels?
Should I expect any rubbing by going that route?
Old Jan 4, 2009 | 01:13 AM
XtinaNoel's Avatar
09 white c63
hey guys when i had my black c63 and i changed my rear tires and left the fronts stock around 60 mph my whole car started to shake bad so i then had to get the stock ones and it wasent happening just a heads up
Old Jan 4, 2009 | 02:57 AM
mthis's Avatar
Anything W/4Wheels
if you do 275/30/19 i think you should be fine not 100%
Old Jan 4, 2009 | 03:01 AM
mthis's Avatar
Anything W/4Wheels
my wheel set up right now
front i have 245/40/18 conti contac 2
rear i have 265/40/18 michey toms
this is by far the best 1-2 punch ever.
no limp mode or anything. take off traction? no problem i floor the car in the street and it does not spin. i can even power brake to 2000RPM and it wont spin.
bottom line if you looking for a tire that can grip in street on stock rims mickey toms are what you need. if you looking to drif around turns forget about this what i wrote.
Old Jan 4, 2009 | 03:41 AM
R8
Thanks, I might just give that a try.
Old Jan 4, 2009 | 11:06 AM
liquiddi's Avatar
2009 E63 AMG
That has nothing to do with if you would have put on a 275 over a 265. You had some bad tires that were out of round. You could do the raked look with the 19's on the back. My C6 is like that. 19's on the back 18's on the front.
Old Jan 31, 2009 | 01:27 PM
Jeanreau's Avatar
997 Turbo GT Silver/Cocoa (sold) 2009 C63 White/Black (sold) 2012 GL350 Pall/Black
Old Jan 31, 2009 | 09:06 PM
soldier2304's Avatar
C63 AMG(sold), 2009 CL550, 2010 S550 Majestic Black, 2010 ML550, 2006 C230, 2009 Venza
Will 265/35/18 rub with H&R springs installed? It's about one inch drop from stock.
Old Feb 1, 2009 | 12:22 AM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
Isn't 275 too wide for the stock rear rims?
Old Feb 1, 2009 | 12:38 AM
OverBudget's Avatar
2009 C63 AMG
Nope, they fit fine in the rear. I even loaded my car with tons of weight and drove from Portland to Scottsdale with no rub...
Old Feb 1, 2009 | 12:59 AM
mthis's Avatar
Anything W/4Wheels
i toled you. now you have to have someone drive your car and you to watch from behinf how wide they look. sickkkkkkkkkk
california amg's Avatar
c63
the only inconvenience of going with a 275/35/18 or 265/35/18 tire instead of a 255/35/18 is that the profile of the tire wall is noticeable higher - in other words the tire doesn't look as thin. However, what you lose in looks you gain in traction...
Old Feb 1, 2009 | 02:15 AM
mthis's Avatar
Anything W/4Wheels
what you think are cars need more looks or more traction?
Old Feb 1, 2009 | 02:21 AM
mthis's Avatar
Anything W/4Wheels
i was serching the web for the cheapest 275/35/18 tire here you go.
http://ssl.delti.com/cgi-bin/rshop.p...se=&LoadRange=
they like $85 each, i think im going to buy some replica rims from ebay and does tires and just keep them for when i feel like doing for 360
edit: the shiping to my house is $65 hahaha
Old Feb 1, 2009 | 04:03 PM
c63
for me it's traction... and that's why I now have 275s in the back!
but for a lot of other folk here it seems that looks are more important - and that's ok! otherwise why go with heavier rims+tires, tinted windows, darken the chrome, etc, etc, etc.
