diggin' da 9500ci
2009 C63 AMG
diggin' da 9500ci
Hello all.
Today I picked up my C63 after being in the shop for the 9500 ci install. I've only driven it 10 miles since, so I'll update this thread when I have experience with its capabilities.
Another memeber recommended the display to be installed in the ash tray in order to help conceal in the hopefully unlikely event one is pulled over. I had them angle it toward me and up for easy viewing.
Pics are below.
Pics are below.
R8
Good job.
I'm not sure if I'd want to butcher my car to do something like that again. I had a double DIN head unit put into one of my NSXs (which were notorious for being hard to mod the stereos), and seeing them cut the center stack was enough to make you want to cry.
But kudos to you for an excellent install.
Hello all.
Pics are below.
Pics are below.
2009 C63 AMG
I paid $1,999 (OK, call it 2 grand). This was for both the product and the installation. My MB dealer in Pittsburgh (Bobby Rahal) just because an authorized reseller and installer. Prior to my install on the C63, they only installed 1 other on a SLR (so although I was only #2, if someone could trust their $500K car I figured I could trust them with my $60K car -- which is about a new brake set for the SLR
They actually spent a total of 27 hours with the install. I presume they'd more than half that on their next C63 and eventually get down to a 4 - 6 hour install time.
I've seen used 9500ci's on eBay for as low as about $1,200 and figure you could probably find someone to install for a few hundred. But for me, it was worth going with my dealer and having a wicked good install IMHO.
Thanks. I will do a search on ebay to find one. I have someone who has installed two of them.
2009 C63 AMG
Shucks
Well, here's an update:
So I just got my 9500ci installed last week on my 2009 C63 AMG.
I was driving about 90 on a familiar highway, had GPS enbled, POP enabled, Auto mode enabled, etc. I was going up a minor hill and at the top was the State Police facing my direction. I saw him before my radar alerted and was able to slow to 80 (which is the speed listed on my ticket). So the sensitivity in this situation was HORRIBLE.
I know I'm not invincible in this thing, but this was a fairly good line of sight. The ticket did not indicate what kind of radar was being used. I was also surrounded by many other cars going rather fast, but I was gaining on the cars in the left lane. So I figure he had been shooting the radar gun even well before I approached?
Needless to say after dropping $2,000 including install, I'm not happy.
In retrospect I should have spent more time doing the speed limit and seeing how this device responded when faced with speedtraps before I started getting more liberal with my speed.
Any advice on what may have happened here welcome, and I'm expecting a few ha ha's--I can take it.
2010 C63
Just my thoughts, but cop was probably using instant-on or POP radar. It is much like laser - once the alarm is sounded, it is too late. However, the radar beam will be scattered a bit if he uses it on someone around or in front of you, and your detector should pick that up. That is why you should always slow down for even a momentary alarm. It sounds like either (1) you were the first one to get hit with it, hence no warning or (2) the system wasn't able to detect the scattered radar signals of someone in front of you getting hit.
Obviously, the second scenario should worry you. Is there someway to test if the system is working properly, or maybe was a short alarm sounded and you ignored it? (Just asking - I have done that before and regretted it.)
1 Post
M5, C63, 335Ci
I doubt you were the first one he used the radar on. The 9500 should have easily picked this up as it was a straight shot and not like he was hidden around a corner, etc. I would have the unit tested by whoever installed it.
Another thing to consider is fighting the ticket. Did you ask to see the radar gun reading? Were there other cars or trucks around you? Radar is not a pinpoint device like laser so he could pick up a reading from a nearby vehicle.
Just my $.02
Q
Just my $.02
Q
2009 C63 AMG
Just my $.02
Q
Just my $.02
Q
So based on the fact I now know Instant On is a major presence where I do my primary driving, the 9500ci was a big waste of money for me. I've used a "rabbit" for years to speed with no tickets. I drop $2K w/ install and bam...nailed.
I'll plead not guilty and hopefully will get a reduced fine/points.
Bummer. Live & learn.
09 c63 blk/blk H&R Springs & 08 e 63 blk/blk
I have the same unit, and it aint a wast of money brothaman. Look, it cant jam radar that's illegal. If it did, airport control towers would be getting all jammed up and we wouldnt want that now would we
? It can only detect it, as you now know. What that means is that as soon as you get a warning you gotta hit the breaks fast.
Law enforcement agencies are moving toward laser (lidar)since it's far more accurate at pinpointing speeders in traffic. Most have already made the expensive addition available. The good news is that laser (so far) must be shot from a stationary position.
This doesnt mean that radar will die. On the contrary, radar will be used for longer less congested roadways. Plus, it can detect speeds going in BOTH directions. This instant on mode that has been developed is a real pain in everyone's *** no question. However, it only reads speed once you have entered the couple of hundred yard "zone" give or take. By then (unless he's totally hidden in the bushes) your eyes and senses should alert you to what might be about to happen.
What does all this mean? Well, for starters, laser will be jammed up untill very close range. That's awesome! I mean, all L.E. uses laser. It's just a matter of time till you get tagged and boy is it a great feeling to stick it to the man!
On open streches of highway, ive been saved dozens of times by cops using radar. The instant on is a little trickier. But, then again, to avoid tickets nothing beats being alert. And a little luck. Trust me, in time youll see what i mean. Even if it only saves you once it's worth the price to play IMO. Keep your chin up soldier!
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
2009 C63 AMG
OK, I'll give it some more time.
On a HWY, going up a slight grade, but a straight grade.
I don't think it's complaining about a speeding ticket that miffs him. It's the fact that he dropped 2 large on a radar/laser detector and it didn't help in sniffing out a speed trap.
Are you a Fed?
Most of us "enthusiast" here find it a little difficult to stay under the posted speed limits (which are usually 25mph lower than the real safe driving limit) as we tend to explore the performance limits of the vehicle.
Any speeding ticket sux.
Taylor-
I would definitely suggest having the dealer check the install given that you were their 2nd install. You said you were gaining on the car in the left lane? Highly unlikely that the lead car in the left lane didn't draw his attention.
Are you a Fed?
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Taylor-
2009 C63 AMG
Taylor-
Taylor-
Yup, that's my issue $2K then ticket. Had 10 years w/o a radar detector + speeding & no ticket.
Actually, I was the guy (fool) in the left lane passing the cars. I've since learned that the Instant On used by LEOs here is unbeatable if you are the lead car. If you have a rabbit ahead and the LEO points the I/O on him/her, than the CI would have picked up on the scatter (not that that mattered, because the rabbit would have been pulled over anyways). Ergo, I feel as if having a radar detector where I/O is the norm is rather useless.
2009 C63 AMG
2009 Mini Cooper Clubman S
Sorry for my ignorance, but what do you mean by using a rabbit?
2009 C63 AMG
2013 Chevy 427 Torch Red
After the dealer/installer finished with my 9500, he checked it out with the 2 radar and one laser devices that he brought with him. In the two months since I have had plenty of notice to all threats but again I always find someone else to run out front. I heard the opinions about the Passport laser shifters being low tech compared to other laser specific brands. However just yesterday I witnessed a LEO in the shadows under a bridge looking confused at his laser gun a second after I recieved a laser shift warning while driving between 70 and 75 on an interstate where the posted is 55 about to be 65. Just up the road were three other less fortunates going through the liscense and registration deal. It was the first time where I knew that I was being targeted and the protection worked just as you would hope.
1 Post
2009 C63 AMG Black on Black PP Package CF fully loaded
After the dealer/installer finished with my 9500, he checked it out with the 2 radar and one laser devices that he brought with him. In the two months since I have had plenty of notice to all threats but again I always find someone else to run out front. I heard the opinions about the Passport laser shifters being low tech compared to other laser specific brands. However just yesterday I witnessed a LEO in the shadows under a bridge looking confused at his laser gun a second after I recieved a laser shift warning while driving between 70 and 75 on an interstate where the posted is 55 about to be 65. Just up the road were three other less fortunates going through the liscense and registration deal. It was the first time where I knew that I was being targeted and the protection worked just as you would hope.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
2009 C63 AMG
Indeed. The 9500ci is good for laser, and very good for all radar bands.
My posts here are to warn anyone considering the 9500ci if their area is full on instant on radar and if their state does not have laser. Yeah, the 9500ci works great picking up instant on, but by definition of instant on, it's too late.
Great story. The look on his face must've been priceless.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Pretty sure that's gonna be my next upgrade for the car. I was thinking ECU but given the drama going on in a few other threads...noooo wayyyy. At least until the smoke clears. I have a V1 that I can't live without and haven't done enough research on shifters to know what I'm looking for.
