Burnout
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Power brake it! Slightly hold the brake with your left foot while gassing it with your right foot. Takes a little practice.
Guaranteed transmission failure!!
2009 C63 AMG Black on Black PP Package CF fully loaded
You need to have ESP in 'Sport' or 'Off'
and it also helps to have transmission in 'Sport' or 'Manual'
Take it easy though, especially if you still have your stock tires. If you haven't seen the trend on this forum, the stock tires(rear) are lasting as low as 600 miles to an average of around 4000 miles. Mine lasted 2800 and I think about half of that was due to a single burnout (it was a fookin awesome one though - about 20 seconds and laid a scratch like 25 yards long!). So, depending on choice of replacement tires, each burnout can cost around $200
Easy ! Listen to me 100% Amazing results FOR SURE
Hold down your ESP button
for a couple secs until it says ESP OFF on your dash
and then
Put your left foot down on the breaks all the way down
Now put your right foot all the way down on the gas
There it should work
If you want to make the smoke show a little nicer
while moving , and leaving a big skidddd mark
you let lose of your breaks slowly and you will start to move ,
and you can move left or right with steering wheel
have fun
Same thing with donuts
steer your steering wheel all the way to one side
Have fun!!!
becareful
and then
have fun
Have fun!!!
becareful
Hey who knows, maybe he plans to run at the strip. When I ran at the strip I was forced to drive through the water box. I wanted to do a really light burnout just to dry em up. Left it in ESP Sport though and once the tires started spinning power was cut.
but putting it in S mode would change gears when it gets to redline into 2 and wouldn't that stop the burn out for a bit?
Next thing you'll do is tell people not to race Hayabusas!
acctually nope, for some reason it does not , i have went through a set of tires already and i have figured that this works very well
The car has enough torque to keep the wheels spinning even in 2nd. If you guys are seriously considering burnouts, you should invest in a line lock that will prevent the rear brakes from engaging when doing a burn out to prevent the rapid brake wear and potentially warping of rear rotors from the heat generated. Also makes doing a burnout a lot easier because you're not braking the rear wheels.
going crusing is WAY MORE FUN!!! haha
