C63 AMG (W204) 2008 - 2015
Coolant Temp after Mobil 5W50 oil change
Old 03-25-2009, 02:59 PM
bwco's Avatar
10' GLK
Well, just did the first oil change myself in between scheduled maintnance, I got the vaccum pumped out all the oil and replaced it with Mobil 1 5W50 supersyn, the coolant temp was lowered.
The coolant temp needle usually sit slightly below the 100 degree celcius mark, but now, even in the morning traffic, it's at 80 mark.
maybe my thermostat got stuck open after oil change? just kidding...
what's your take?
Old 03-25-2009, 04:30 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Ummmm....
Isn't M1 5W50 recommended for the SLR only?/
The recommendations from AMG are that after May 2008 (the automotive fluid standards changed in May 2008) the following fluids should be used for AMG engines :
- Mobil 1 5W-40 for M156 engine (63er models)
- Mobil 1 0W-40 all other AMG engines (as well the AMG diesel engines that was used for the C 30 AMG)
- Mobil 1 5W-50 SLR engine
Before May 2008, the Mobil 1 0W-40 was used for the 63 models as well
Old 03-25-2009, 04:32 PM
jarjoug's Avatar
2006 BMW 330i, 2009 C63
The dealer put 0w40 in mine.
George
Old 03-25-2009, 04:40 PM
George
Hey George. See you were hit with another Snow storm. Hope spring heads your way soon. Put my summers on today....
I am running 0W40 now as well. Switching to 5W40 at the next change in a few weeks on the advice of my shop foreman (summer temps)
Old 03-25-2009, 05:54 PM
bwco's Avatar
10' GLK
yes, our dealership recommend 0w40, but i have a few jugs of 5W50, and I see that our engine runs hotter than others, also, i may sacrifice a few miles per gallon which isn't a big issue. So, I did put the 5W50 in. No ill effects right now, let's see the long run. It's good for SLR, it's good enough for a 6.3
Old 03-25-2009, 06:27 PM
Timeless's Avatar
2005 E55 ///AMG
I'm pretty sure your car has zero in common with an SLR...much specifically engine wise.
Using the incorrect weight can also void your warranty if the dealer wants to and finds out. So unless 5w50 is in your owner's manual, I would stay away from it.
Old 03-25-2009, 07:34 PM
bwco's Avatar
10' GLK
err, we both have pistons, injectors, crank, cams, valves, and need engine oil. The similar thing is, both engine have the same badge on it !
Well, i don't like to follow rules. That's why I put 5W50 and i know full well of the warranty part !
MykhailoM (04-21-2020)
Old 03-25-2009, 07:43 PM
jarjoug's Avatar
Hey Barry, can't wait for the snow to melt. I am getting new 265 tires for the back and 245 for the front.
George
Old 03-25-2009, 08:14 PM
Well...I'm sure the 5W50 won't kill your engine (Kill your warranty maybe..lol)
But why oh why for the sake of saving a few bucks would you use up a few jugs of slick you had laying around in the garage beats me?? I for one wouldn't stray from the AMG recommended viscosity for the M156.
Just my 2 cents....It's your car you can do what you want with it
Old 03-25-2009, 08:15 PM
George
Cool...(pun intended) What tires did you go with??
Old 03-25-2009, 08:37 PM
norb's Avatar
2009 C63 AMG
This place doesn't think the manual is worth reading, people think lawyers wrote it.
Old 03-25-2009, 09:23 PM
jarjoug's Avatar
I am going to get Nitto.
George
Old 03-26-2009, 02:47 PM
bwco's Avatar
10' GLK
yup, i know i know !
Old 03-26-2009, 05:41 PM
Timeless's Avatar
2005 E55 ///AMG
but it's such a waste to not use these left over oil. I still have a few jugs sitting around. I used these oil for the F360 and thought it won't hurt a Mercedes engine. Oh well... Thanks anyways !
I'm pretty sure this also recommended 5w40.
Old 03-26-2009, 05:52 PM
mthis's Avatar
Anything W/4Wheels
Which oil keep the motor oil temp lower. My car runs at 220 to 242
Old 03-26-2009, 06:51 PM
When I had my F360, my Ferrari Master Mechanic recommended Mobile1 0W40 for daily Summer driving and Castrol 10W 60 for Track Days...
Old 03-26-2009, 07:53 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
I wonder if we're maybe reading too much into this I don't think 5W-50 will hurt the engine at all..... although it may hurt your wallet I would assume the SLR engine needs it more since AMG/McLaren worked hard on squeezing a lot of power out of it. But supposedly, the 5W-50 is a better oil with more LDDP
Old 03-26-2009, 08:23 PM
Your right....Its just been very slow around here the last few days and I needed something to chew on.
Old 03-28-2009, 12:48 AM
mthis's Avatar
Anything W/4Wheels
so what oil is best for hard hard driving
Old 03-28-2009, 12:56 AM
MB_Forever's Avatar
I'd use the new 5W-40 that AMG is recommending. Be very careful when getting it though because most of the Mobil 5W-40 sold at Auto stores are actually for trucks and diesel. I think the dealer is able to special order the correct 5W-40 for you.
0W-40 is not the recommended anymore for our 63 engines (as of May 2008).
I know of a couple of people that have been using the 5W-50 on their E55 with no problems what so ever, but never heard it being used on the 63 engines.
Old 03-28-2009, 01:03 AM
mthis's Avatar
Anything W/4Wheels
ight can you school me on oil reading or weight or something i dont know jack about oil.
Old 03-28-2009, 11:35 PM
Multispeed's Avatar
C63
You do realize that coolant temp is controlled by the thermostat and the oil quality wont make any consistent or noticable difference in coolant temp.
You also dont have to use Mobil 1, it is only recommended.
There are better oils out there and you wont lose your engine warranty.
Mercedes has had this same uptight "Approved" list over the last 32 years I have been doing maintenance on them. I dont trust their recommendations regarding maintenance or engine oils. Just ask a Mercedes rep why the company got hit with a class action suit early in the new millenium because of thousands of damaged enigines in 1998 to 2001 vehicles. It cost Mercedes a reported $118 million.
Old 03-29-2009, 01:02 AM
MB_Forever's Avatar
Here's a quick crash course.....
"Oil weight, or viscosity, refers to how thick or thin the oil is. The temperature requirements set for oil by the Society of Automotive Engineers (SAE) is 0 degrees F (low) and 210 degrees F (high).
Oils meeting the SAE's low temperature requirements have a "W" after the viscosity rating (example: 10W), and oils that meet the high ratings have no letter (example SAE 30). An oil is rated for viscosity by heating it to a specified temperature, and then allowing it to flow out of a specifically sized hole. Its viscosity rating is determined by the length of time it takes to flow out of the hole. If it flows quickly, it gets a low rating. If it flows slowly, it gets a high rating.
Engines need oil that is thin enough for cold starts, and thick enough when the engine is hot. Since oil gets thinner when heated, and thicker when cooled, most of us use what are called multi-grade, or multi-viscosity oils. These oils meet SAE specifications for the low temperature requirements of a light oil and the high temperature requirements of a heavy oil.
You will hear them referred to as multi-viscosity, all-season and all-weather oils. An example is a 10W-30 which is commonly found in stores. When choosing oil, always follow the manufacturer's recommendation.
Old 04-03-2009, 01:24 AM
1Lop2K5C's Avatar
C63
A couple of the dealers in my area are starting to use 5W-40 ESP for both 63 and 55 engine now. Where can I get them beside the dealer? TIA
Old 04-03-2009, 01:33 AM
mthis's Avatar
Anything W/4Wheels
thanks make alot of 0.01
Quick Reply: Coolant Temp after Mobil 5W50 oil change
