Another tire thread
#102
1 Post
2011 GLK350, 2010 ML350, 2008 C63 AMG
Got Continental Extreme Contact DW tires yesterday. 235/40/18 front and 265/35/18 rear. Hope they'll be good replacements.
http://www.tirerack.com/tires/tires....remeContact+DW
how come you didn't do a wider tire in the front like 245?
#103
1 Post
axe muderer with headlights
Just switched out my rear oem Pirelli P-Zero's @ 5k mi. I was going to go with what I've had much success with the in past (Falken FK-452s), but from a recommendation of another Forum member + in doing some research, I decided to try the Bridgestone Potenza RE760 Sports with are similarly priced to the Falken FK452s.
A couple things I've noticed in the past 2 days of driving on them (mostly on the highway)...
1. The a/s tread pattern is actually quite similar to the oem Pirelli P-Zero's.
2. I'm not sure if they need to "settle in" or not, but it seems like I'm getting a lot more "float" on the highway...no pulls to the right or left; just like a "floaty" feeling like when it's very windy, but even when there's little wind. I wonder if this is b/c of the two different tire types on the front vs. rear?
3. The Bridgestone RE760's are quiet for now and they seem to grip quite well, although I haven't really driven on them in the rain yet or done any hard launches.
4. They have a treadwear rating of 340 (vs. the Pirelli P-Zero's 220), so time will tell how many mi. they actually last on the rear of my beast.
I will update everyone on my experiences with the Bridgestone RE760 Sports in a few days, but for now, if anyone has any thoughts as to the "float" I'm feeling, please chime in. Thanks you.
#104
'09 C63 AMG
They seem better now; maybe they just needed some time to "settle in." Anyhow, I did the NitroFill (nitgrogen instead of air) in the new rear Bridgestone Potenza RE760's (matched the front OEM Pirelli P-Zero's with nitrogen @ 39psi) and they seem fine now. IDK; I'm just hoping I get at least 10k mi. on these rear tires. If not, I'm going back to my Falken FK452's.
#106
i need some help asap on tire choosing
ok i have been reading the threads and i have seen alot of people posting different tire sizes and i have called alot of places and so far i have not yet found a tire size 275-30-18 and i want to put those on the rear stock rims of my c63 and i want to put in the front 245-35-18 what would be your opinions on tires...and then i heard that there are all season tires and then there are summer tires.....if anyone has any information on where to get the tires or what should i put i would appreciate it....
#107
'09 C63 AMG
#108
Tire sizes
WITH AN 18" RIM YOU ARE PROBABLY LIMITED TO 265'S. WITH A 19" YOU CAN GO 10" WIDE ON THE RIM WITH 285/30'S. WITH A 20" RIM YOU CAN GO WITH A 10.5" RIM. TIRE SIZE WILL PROABLY STILL BE LIMITED TO 285. MAYBE A 295 WILL FIT BUT I'M NOT SURE. I HAVE 10" X 19" WITH 285/30 RUBBER AND HAVE PLENTY OF CLEARANCE
#110
2009 C63 with Eurocharged tune and charcoal delete
I got Sumitomo HTRZIIIs about a month ago from Tire Rack ($165.00 each) and am quite happy with them. Too soon to tell if they will last longer than the pathetic PZeros, but they have a 280 treadwear rating and they cost much less than the Pirellis so they should be a winner.
#112
#113
C63 AMG
PZero Nero A/S
I had the Nero all seasons put on the rear about 2000 miles ago, and I have been happy with them. They are definitely not a sticky tire in the dry, but wet cornering performance is great. They were relatively cheap, and they have a pretty good treadwear rating. I would rather have some stickier tires for hard stop light starts, but I do not have the time to keep going back to the tire shop. Wet performance and treadlife are paramount. They are a bit more comfortable. I can feel a hard bump from the stock PZeros on the front, and a bit softer thump from the rear Neros. Unfortunately this translates into a floaty ride making high speed lane changes… interesting. Can anyone report on the extreme contact DWS? I am seriously considering these.
#114
Black '09 C63
so far, i'm understanding that going 245/275 will NOT have any problems on the 19 inch OEM rims. BUT i did want to re-ask a question i think you guys ignored, from gsrjc. Does going with fatter tires mess with the speedometer? It's a pretty important question IMO
#115
'10 F150 FX4 SCrew. '14 S212S
#116
2005 Mercedes G55 AMG
Wider tire does not affect you Speedo. I think the speedo is affected only if the tire is taller... At least that is what I always heard.
#118
I want to say, or have heard, that it's connected to the tranny at some point. But if the diameter of the rear wheels changes, then your speedo will be inaccurate. Larger than stock diameter = speedo reads slow, vice versa.
