Downshifting into 1st Gear...
09' C63 AMG
I have been told by a few different people while in the car with me driving, that downshifting into 1st gear while in M mode is BAD for the car...
Is this true?? I hope not because I do it ALL the time?
Can someone please clarify this? Thanks.
Immediately after downshifting where is the RPM needle at? If you keep on doing it and it downshifts at 6k all the time then I guess it can cause faster wear and tear on the transmission.
2009 C63
I was actually thinking about this recently. In S mode I downshift all the time, thinking it's better than wearing out the break. Is this bad? And sometimes I'll click it down multiple times in a row in somewhat quick succession.
1 Post
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
If you are in M mode and leave it in say 4th gear and cme to a stop you will see that the transmission will downshift all the way into 1st. But, the transmission wil only downshift into 1st at about 5mph. I would venture to say that downshifting into first going any faster than 10mph will put undue and harmfull stress on your synchros.
C350 4Matic
There is no need to shift into 1st. By the time you can your almost stopped anyway. Just watch the RPM's any time you downshift to any gear to make sure your in control and not trashing it for no reason. Quick and multipal down shifts are fine during aggressive driving...hell its the only way!
Mini S Cooper, C63 PP+ 2010
with the modern cars and especially with automatic gear box you cant ruin your engine/gearbox any more.
The software will prevent downshifts at too high rpm's.
So you can downshift into 1st whenever you want/whenever it is possible - and it is not bad to your car at all!
R8
No, its not bad. Treat your car with love and care and you wont have anything to worry about. Down shifting into 1st gear at 7,000 RPM, ill let you assume whether its "harmful" or not.
S or M mode, I always shift it back to first from below 20-25km/h in general driving around town. I'm only on the brakes for the last 5-10km/h to stop. My dealer has no problem with this practice and as has been mentioned, the car 'knows' what it's doing and won't allow the nut behind the wheel to shift to first if the kick down rpm will be too high. Enjoy the noise I say!
