C63 AMG (W204) 2008 - 2015
What does dashboard temperature gauge measure?
Old Jun 11, 2009 | 04:05 PM
dps01's Avatar
2009 C63 AMG
The digital temperature gauge that's built into the driver's main console (the computerized one that rotates between speedometer/fuel efficiency/etc.) always seems to be about 20 degrees higher than the actual outside temperature.
Is this normal? For example, maybe it's measuring the engine temp. and not the outside temp. Or is it clearly broken and I need to get it fixed.
The ones on my E46 and E92 of course was always dead accurate. Thanks guys.
Old Jun 11, 2009 | 04:24 PM
ARC101's Avatar
2008 C63
I thought it was outside temp but it is always off at start-up. I guess it depends on where the sensor is positioned as to how accuratly it reads.
Old Jun 11, 2009 | 07:11 PM
Ape's Avatar
Ape
2004 TL; 2004 S2000; 2009 C63; 2009 ML350
I have the same issue with mine reading higher then the real temp outside. I asked the dealer to look at it when it was in for service and they said that is normal for MB. Wife's ML350 is also always reading higher then the actual air temp. My Acura was always dead on, I am not sure why Honda can get it accurate but MB is so far off.
Old Jun 13, 2009 | 01:33 AM
DaGS1800's Avatar
09' C63 AMG
This is so true, I live in Miami and when I get into my car sometimes it says like 110 degrees This is very frustrating...
I am curious; does everyone’s temp level by the speedometer which measures the engine heat always sit a bit higher than the half way mark? or is there something unusual with my car? On every other car I’ve had it would always stay at the halfway mark or lower, never higher... is this normal???
Old Jul 23, 2011 | 12:34 PM
FrankBoni's Avatar
2005 S500 4 Matic
All, I have the same issue on a S500 4matic and live in NY. Weird but I can live with it. I thought maybe the sensor was positioned too close to the radiator or engine. I wouldn't even know where to look. If anyone does find out lmk. Thanks
Old Jul 23, 2011 | 01:20 PM
mthis's Avatar
Anything W/4Wheels
Guys if u park in the sun it will shower 20+F higher then what it is,
Try parking in the shade and check the temp and see how accurate it is.
My car is point on and I actually try this yesterday bc I di t believe it was 108F and I check weather.com and it said actual temp was 100 but the feel like temp was 109F so my car was close.
Old Jul 23, 2011 | 01:33 PM
C63newdude's Avatar
C63 AMG
I didn't make a deal out of this but I have seen 124 degrees many times on my cars in Tucson, mainly when the car has been parked outside in the sun for hours.
Old Jul 23, 2011 | 01:34 PM
bluejae's Avatar
'10 C63
mine is usually pretty high.. but then lowers after a few minutes of driving... it's most likely where they chose to put the sensor...
i had a 2012 ford focus rental and after parked in the sun for like 9 hours... the highest i ever saw it was 120f
Old Jul 23, 2011 | 02:32 PM
rory breaker's Avatar
Yes
Every car I've ever owned has had a slightly inflated temp reading...guessing it depends where the sensor is, if you park in the sun, road conditions (highway vs back road), etc.
Old Jul 24, 2011 | 09:18 AM
FrankBoni's Avatar
2005 S500 4 Matic
Thanks everyone for the comments. I'll leave by saying yesterday she was parked under a tree all day, went to lunch with the family, the temp spiked to 131! Went down a bit but there is something inherently wrong with the sensor or the position it is in on the car. Granted it was 100 here in NY with 100+ humidity but still. The old town and country ( minivan) had it right
Old Jul 24, 2011 | 09:30 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
If your temp sensor has popped off, inside the car, the sensor could be reading the temperature inside the engine bay. Mine, came off on my E63. The sensor just snaps in place, and poke through the left lower grill. That could explain the variance in temperatures.
Old Jul 24, 2011 | 07:40 PM
Mort's Avatar
I have read about the sensor getting dislodged and falling behind the bumper grill a few times and it does seem to result in elevated ambient temperature readings. It is relatively easy to put back in place if you remove the front belly shield.
Old Jul 26, 2011 | 11:21 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
What mort said is correct. when the sensor (in the lower left side of teh grill, it looks like a little black bubble sticking out.. or just a round hole if it fell in) is inside the grill area.. it's like a solar oven beating on down on black plastic.. I had to pop mine back in.. it read 150' last year during hyperfest at summit point race track.. the days weather was 105 (felt like 150 though...)..
Old Jul 26, 2011 | 11:52 AM
OrientBlue3's Avatar
ED1 e63S
Mine read 120 yesterday.
Old Jul 26, 2011 | 12:17 PM
Stillpt12's Avatar
CLK-320 Convertible 2005
Mine does fine. Sounds like good suggestions!
Old Jul 26, 2011 | 12:26 PM
tpick23's Avatar
E63
I pulled my cold engine car out of the garage the other day and it sat in the sun where the sensor was in direct sunlight. The temp was 117.
I also had the sensor fall out of the housing (when I installed the laser sensor) and it was lying in the inside of the wheel well. It read 147 then.
Old Jul 26, 2011 | 12:53 PM
Yuille36's Avatar
So you see the temperatures can be off by allot depending, if the sensor was dislodged from it housing. My E63 sensor seems to be on mark though.
Old Jul 26, 2011 | 03:31 PM
FrankBoni's Avatar
2005 S500 4 Matic
All,
I have a2005 S500 is the sensor in the same location does anyone know?
Old Jul 26, 2011 | 03:48 PM
Yuille36's Avatar
FrankBoni,
I would have to probably yes, but I'm not totally sure. Their in the same location on my C63 and E63. Come to think of it, it has been in the same location in the (5) Mercedes I've owned. Just check to be sure.
Old Jul 26, 2011 | 04:05 PM
FrankBoni's Avatar
2005 S500 4 Matic
haha, thanks. I'll check it out and report back. My first Benz what do i know. The other cars, if you wanted to know how hot it was outside, you stuck your head out the window!
Thanks Yuille
Old Jul 26, 2011 | 07:25 PM
FrankBoni's Avatar
2005 S500 4 Matic
All, it not in the lower left grill of the s500
