Any improvement in reliability with the new C-class and C63 AMG?
1. Check Engine light going off 2 days after owning the car. Solution was a replace defective purge valve in gas tank causing emissions fault.
2. Rear Pirelli Tires are GARBAGE. Finally on my 3rd set of rears but completely changed over to Michelin PS2's
3. Car tends to burn oil
However....None of these things are major mechanical defects....If you want to hear some horror stories go over to M3post.com and in the general forum you will see some truly nightmare stories from M3 owners. Transmissions, Software, Differential, Cars going into Limp Mode, you name it.
What do you mean by burn oil?
it consumes more oils than other cars. I haven't had that minor issue yet, but i hear after a certain miles it will eat less oil. This is just an assumption i have come up with when searching through previous threads about oil consumption. I'd say it is fairly normal for these engine to consume oil.
1) Bad purge valve
2) Solenoid inside the cabin replaced (making strange noise when reaching a stop)
3) Rubber moulding around the plastic panel that funnels the air into the intake was disintegrating
4) Check engine light
5) Delaminating front tires (caused radial pull)
6) Alignment required
7) Mystery transmission fluid on bottom of bell housing between engine and tranny
8) Rear tires are complete junk (as everyone knows)
9) Rear bumper cover warping
10) Oil consumption (not a defect per se)
Every performance car that I have owned consumes oil. Both my M3's and even my 330i PP required at least a couple quarts between oil changes.
