Which ECU Upgrade should I do???
Also, the K2 version is just as much DD as stock. I put the car in "C" mode when I want to chill (which is rare). But in "C", it drives and sounds much like stock if you drive it like a normal person.
Put in "M" or "S" and it's crazy fast.
I'm also told the adaptive learning from the ECU is setting-specific. Meaning, just puttering around in "C" won't affect my adaptive learning on "S". Seems to be that way.
I know on BMW the shift modes aren't able to change your fuel map or any of that crazy stuff.
In a quick and dirty explanation the C63 in S mode will not only downshift the car when on the brakes but blip the throttle to make sure the downshifts are smooth and more effective.
This is the first car i have had with a paddle shift and "smart" tranny computer. I must say that I have been racing for 19 years and have never had a car that does all the right things at the right time (by itself) than the C63. I believe, and this is just my opinion, that S mode will out shift and beat a driver in M mode any day. This is coming from a guy that has been racing against Porsche Cup cars in competition for the last 4 seasons against the newer Cups that come with a sequential dogbox. I am racing a Cup car with a standard H pattern 6 speed that requires the driver to master the heal toe technique to be one of the fast one out there. If I miss a shift or don't match the throttle to gear exchange then i loose a turn and the newer cars can jump ahead of me.
So back to the C63... The driver using the "manual" setting can only make that an advantage if they can master the shifts when going into a turn, or coming out of turn. They key is mastering the art of momentum and carrying it though the turn. The beauty about the C63 is that in S mode the car does this on its own. Yeah, it may be fun to drive in manual mode because the feel of the car is so present. However when you can't feel the car doing what needs to be done you will be faster on any given day. The smoothness of the C63's tranny and engine maps is excellent. I guess if you really practice and learn a course very well you may be able to out drive the computer. However when Porsche came out with the Tiptronic tranny that learned as you drove it I became a believer in the new technology that has only gotten better year after year. **** F1 has had this for years !! Cheers Andy
good luck with your decision
You would most likely have 3 smiles!
Personally, cost/HP is my favorite direction...
Let me know if you have any questions, I can explain in detail about the tunes.
-Adam
Good Luck
