thoughts on mixing tire brands
Any reason for that? What about the car with PP? if I don't track often at all. Thanks
I had toasted the rear Pirelli P-Zeros and installed 4 Bridgestone Re050 PP's on the old gal. Suddenly, the handling improved markedly to nearly that of my older car. I was very, very pleased with this. I had Bridgestone Fusions ZRi's on the old C36 and apparently they have some of the same carcass traits as the much more costly Re050's. Just something to consider if you also find the steering in the C63 to be "Underdamped".
Irish
Heard the Kumhos wear about 10% faster on the track, however, best bang for the buck!
We put the 19" Kumhos on our 05 Infiniti G35 and they're doing great, two years on them now and will be installing a set of 4 for our next C63 AMG tire change. Maybe someone will want our front stock used tires.
Bottom line, we're not advocates of mixing new and old tires.
Good luck with your decision.
Actually, these numbers give you general sizing ideas. I am surprized why we rely on these numbers soooo much.
I ALWAYS check the individual tire model specs that are available from the manufacturer when I change brands or sizes.
You will find that some 265/35s match quite closely to the p-zero 255/35 even though it makes sense that 265/35 would be a bit taller.
Check overall diameter and revolutions per mile for better comparisons.
