C63 AMG (W204) 2008 - 2015
AMG 6.3 high-flow airbox demystified
Old Aug 25, 2009 | 04:53 PM
Sincity's Avatar
Originally Posted by NORTH 44 C55
A 156 090 05 01 / A156 094 056 06
I found these on the front edge of the Box Top between 2 raised dots, beside the slot that Front Engine Cover clips into.
jjb03: Could you kindly/please get us these #'s from your Box Tops for reference??
Thanks in advance for your time.
Lomita: Could you please do the same so we can cross-reference?
Old Aug 25, 2009 | 05:23 PM
Vadim @ FD's Avatar
S600TT, R350
Vadim: You were the first here to discover the extra power gained by removing the charcoals. Do you think that if we grind out the flat sections (pic # 2 & #3 above) of the air funnel, will it throw off MAF readings?
I think you will be OK.
Ususally when you change the airflow through the meter by over 20%, than the ECU throws a code.
Old Aug 25, 2009 | 06:12 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Auzie Part #'s Located
Tracked down what I think are the correct Part #s for the Auzie BoxTops and waiting for confirmation from my Parts guy in Stuttgart . Due to time difference it may be tomorrow morning before I hear back.. Stay tuned
Old Aug 25, 2009 | 06:20 PM
jjb03's Avatar
c63 AMG, BMW 335 conv
Sorry i havnt been back to you guys. (time difference)
I am at work now, will get the nos when i get home.
Cheers.
Old Aug 25, 2009 | 06:33 PM
B-52Gunner's Avatar
C63
I'll be buying a set of these bad boys once someone comes up with the part numbers
Old Aug 25, 2009 | 07:49 PM
Sincity's Avatar
Alright jjbo3 @ North, thanks for the work! Then I wonder if we can order them from our local Benz parts guy? It would be much cheaper if we could get funnels made.
Old Aug 26, 2009 | 01:33 AM
  #32
jjb03's Avatar
Ok Guys here are the nos. Dont ask me what they mean.
left side is A1560900301/A1560940306
4010845/0611057A
right side is A1560900401/A1560940406
4010846/0611059A
Hope this helps
Cheers JB.
Old Aug 26, 2009 | 09:41 AM
  #33
Thanks Mate.
Old Aug 26, 2009 | 11:00 AM
  #34
Sincity's Avatar
Tks JJB! Now I need to take these #s to my local dealership and see what they make of it.
EDIT: Called the dealer and they can order them. Here are the PNs to use:
LT side A1560940306 $314
RT side A1560940406 $314
It takes 5 business days from Germany to the dealership. I wonder how these compare to the Carbonio?
Edit 8/27: Corrected ROW PNs.
Old Aug 26, 2009 | 11:27 AM
  #35
Sincity's Avatar
Originally Posted by Sincity
Sent a note to Revozport (they are still sleeping in HK).
Revozport: Could you please confirm if the airbox funnel in Hong Kong is the same as the one on the left. If so, do you think your company will be interested in manufacturing high-flow air funnels out of CF so we can retrofit them into our boxes? This may be an oppurtunity since all AMG 63 engine boxes in North America are the same throughout the entire product line.
Ken from Revozport responded to my PM. This is something that they may be able to do. Of course, it has to make business sense to them to reporduce the higher flow air funnels. Good thing that all 6.3 AMG engines in the Americas all use the same airbox type so there is a business opportunity for them. We just need to let them know that a demand for these funnels exist. However, this is a DIY project where you will need to Dremel out part of the black lattice frame (where the funnel meets) in order to fit the new funnels so this is not a project for the feint of heart.
Old Aug 26, 2009 | 11:40 AM
  #36
LT side 1560940506 $314
RT side 1560940606 $314
That sounds about right. I'm still waiting for Germany to reply. They do like to take their time. Especially in August...LOL
Carbonio actually used this German BoxTop as a template for their CF box set then enlarged the box itself along with some wind tunnel testing for Flow Dynamics
Old Aug 26, 2009 | 12:12 PM
  #37
Sincity's Avatar
After all of this fuss, I wonder how much of an improvement do these funnels provide?
Old Aug 26, 2009 | 12:25 PM
  #38
pmknapp's Avatar
C63, SLK, F150
Maybe nothing if the motor like mine is stock and the TB's only open to about 50% anyways. So maybe nothing much gained in that. Only benifit I could see is less terbulant air into the intake system because I am sure ther are huge vortex of air in that top and funnel area.
Old Aug 26, 2009 | 01:09 PM
  #39
Vadim @ FD's Avatar
S600TT, R350
Without software upgrade to open up throttle plates to 87%, other mods will not have as much of the benefit.
Old Aug 26, 2009 | 04:56 PM
  #40
pmknapp's Avatar
C63, SLK, F150
Vadim what is the stock Throttle Plate (TB) opening. I was under the assumtion it was about 50%. When its tuned does it then open it to about 87%? What tune or do all tunes do that? Why not more like 95% or more?
Thanks.
Old Aug 26, 2009 | 05:40 PM
  #41
Vadim @ FD's Avatar
S600TT, R350
Thanks.
Under WOT stock software opens intially to 60%, than about second later it goes down to 50%. IMHO, it is done to give initial jolt of acceleration, but ultimately is designed keep the car down to 451HP.
87% is the limit of the map. For all purposes going further probably will not yield a big increase in flow. BTW, we are taliking about two 74 mm TBs that together flow over 1500 cfm.
I am still not sure why AMG went with two TBs, they are under "cost control gun", and a single 82 mm is still cheaper than a twin 74s.
Direct injection??? SLS style IR manifold???
Old Aug 26, 2009 | 06:00 PM
  #42
You have my interest peaked!!!
Old Aug 26, 2009 | 08:12 PM
  #43
andrew89930's Avatar
2009 C63
guys this is very simple. the e63 parts are the same as the ROW (rest of world) intake c63 parts. got min in 2 days from my local dealer. under 300 for the pair. the bmc filters cost more than the box tops .
Old Aug 26, 2009 | 08:31 PM
  #44
lomita's Avatar
C63AMG
No Way
Can't be this easy, this is rocket science stuff.............
Old Aug 26, 2009 | 08:38 PM
  #45
2009 C63
oh but it is my friend !!
Old Aug 26, 2009 | 09:58 PM
  #46
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
With these box tops in other parts of the world, the cars are listed as producing 457hp as opposed to our 451hp in the americas, i wonder if this is the reason for the difference in hp?
Old Aug 27, 2009 | 07:04 AM
  #47
B-52Gunner's Avatar
C63
andrew89930 you are saying the factory US E63 airbox covers are the same as the images provided by sincity (without the latice for the charcoal filters)? interesting.
Old Aug 27, 2009 | 07:18 AM
  #48
MUZZIE's Avatar
2017 AMG C63S Coupe , Range Rover Sport
I thought it may have been the Higher Octane rating available in other Countries.
Old Aug 27, 2009 | 11:20 AM
  #49
Sincity's Avatar
I don't think that is correct. I pulled up the E63, CLK BS, SL63, S63 and they all share the same PNs with the C63 (1560940506 and 1560940606). Unless there was a late year change. Andrew, do you know someone with a US spec E63 with the ROW boxes? I discovered yesterday that you can get these from the dealership (with PNs and prices) so that part is no longer a mystery.
I have been PMing Ken @ Revozport back-and-forth on the possibility of replicating these funnels. If he is willing to do it, it would be much cheaper than buying new boxes since the only differences is in the funnel. To fit these funnels, if Revozport will make them, will require you to grind out a small section of the black frame at the air tubes.
I too, thought that the 457HP was probably due to the boxes until someone brought up the octane issue. Then again, as pmknapp and Vadim mentioned, it may not do much until we have a tune.
Old Aug 27, 2009 | 02:14 PM
  #50
Jae Duk's Avatar
'09 C63
I thought only CA and NV and maybe of couple of other states were restricted to 91 octane? While the rest of the States are higher than that? If that is true then why would they say that America is only restricted to 451 while other countries are 457? Doesn't that mean that Texas C63s are closer to 457 if not 457.
