evosport ecu upgrade
c63 AMG
i know evosport using powerchip for ecu upgrade. how much power gain from only ecu upgrade in real number?
c63 AMG
people from powerchip are in NY and NJ area, i called up the guy asking for ecu upgrade. he told me 30hp gains,instead of the figure we saw from evosport.
Seriously, noone wants to read this 3 month old post, when there's a whole sticky devoted to it. Check the date before adding any insightful advice.
Yes. But we can also tune for 93.
Powerchip is located in California, not in NY or NJ. If you called someone in NY or NJ you called a dealer and you were given the wrong information. 30hp is for a NON C63. The gains for a C63 are much more. Please do a search. We have a dedicated post on the C63 tune with dyno sheets. Or you can pick up the phone and call us to ask questions.
The gains are the same.
I havent seen anyone with a PC c63 ECU, but many with MHP that have had great gains. If the gains are the same and PC will guarantee it I would imagine PC is cheaper correct?
Former Vendor of MBWorld
2009 - C63 Black/Black
I went with MHP but only after trying 2 other vendors products that did not provide the claimed hp/tq gains. After the dyno I got an additional 65rwhp and 27rwtq….. They also offered a full money back guarantee if I was not happy with the results.. Former customer turned distributor!
Did your post get deleted because I do not see it now?
Here is your post question - "You went with 2 other vendors when you are a MHP vendor lolz ?"
Yes it’s true however I only became an MHP distributor after trying the other 2 vendor products and for what ever reason I did not get the gains that they claimed on their websites. I' still fighting with both of them to get my full refund.
2009 C63
2009 C63
C63 AMG Arctic w/ Stage 1 Tune, DoubleXX pipe, MCD-631X coming soon
I'm not going to try and argue with you. However, you did state in a previous topic that there was a problem with your ECU and you had to get it replaced from the dealer if I recall correctly? And you went with MHP after the ECU was replaced. Like I said before maybe it was a faulty ECU which is probably the reason why you got no gains? I'm not saying MHP is bad, they have proven their numbers. But it just seems like you're trying too hard and trying to say everyone's ECU tune is not as good as MHP's. To be honest, and in agreeing with Brian's post all ECU tunes should be roughly the same result. Of course the more money you spend the more result you're most likely going to get. However, there is also history proven that MHP might not be reliable? It's not saying you're a bad sponsor or a bad person, just saying that some things don't make sense.
But props to MHP spending the most time in developing parts for the C63
