general 63 question on the AMG motors
What is its weakness? Is it overbuilt as it appears to me?
Since they are now at about 570 normally asperated on the SLS, I would think that would be the route to take.
Pistons - we wanted forged pistons as they hold up better to detonation than hypereutectic. I don't know what the merc C63 has stock.
Compression - Anything over 9.5:1 and higher boost is a challenge (not undoable.... just more challenging). I'm running 14psi of centrifugal boost on a 9.5:1 motor now and the tune is critical to stay out of detonation. Colder spark plugs, 93 octane fuel, and conservative tune are a must... plus I ride around with a wide-band O2 sensor in the car to datalog runs occasionally just to be sure something hasn't come-up. My AFR across the rpm range in boost is 11.2 and drops to 10.8 at top rpm.
Fuel System - injectors / fuel pump / fuel lines..... not sure how overdesigned these are...... to handle another 100-120hp from 8-10psi of boost.
Cooling System - When you add a blower you get more heat..... but I suppose the stock amg system can handle it....
on and on and on...... tuning is fun and expensive
