C63 AMG (W204) 2008 - 2015
Right tire wear > Left tire wear?
Old Nov 24, 2009 | 09:03 PM
Dk1's Avatar
Dk1
2010 C63 / 2009 GL450
I wonder if anyone can answer this for me. I have about 2500 miles since I picked up my 2010 C63. I followed the break in procedure for the first 1000 miles. After the break in period, I did not drive the car hard except for rare quick acceleration as I do mostly local driving.
Yesterday, I checked the tire wear for the rears prior to changing over to the winter set and noticed that right rear seems to have worn out significantly more than the left.
Can anyone explain this to me?
I do not have a limited slip differential. Will installing a LSD help this phenomenon?
Just curious as to what causes this...
Thanks in advance
Old Nov 24, 2009 | 09:13 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Thanks in advance
You already answered it yourself.
Old Nov 24, 2009 | 09:27 PM
hhughes1's Avatar
2013 Chevy 427 Torch Red
Rotate the rears if the 2010 has P Zeros
Old Nov 25, 2009 | 10:32 AM
Palladin's Avatar
2009 C63 with Eurocharged tune and charcoal delete
I had exactly the same problem and several people on the forum confirmed that its common on cars without LSD. Apparently the car puts most of its power down through the right rear tire (as do most cars without limited slips). A couple people with LSD even said their car wears the right rear faster than the left. The PZeros are realy soft and dont last very long, so many people switch to a tire with better tread life. I went with Sumitomos HTRZIII and like them a lot. You will be replacing rear tires quite often on this car, so it all depends on your budget and driving style. Good luck and enjoy the car.
Old Nov 25, 2009 | 11:07 AM
eagle_lex's Avatar
2012 E350 4matic
i have almost 2,500 miles on mine and i cant see a visable difference in the tire wear yet. but i never turn traction control off. do you disable your TC much?
Old Nov 25, 2009 | 01:05 PM
exdes's Avatar
2015 C300 4matic
so it's okay to swap left rear with right rear? the stock pirelli tires are not directional?
Old Nov 25, 2009 | 03:42 PM
hhughes1's Avatar
Nope, there is no rotational arrow simply an outside designation for the tire mounter. Take one off and sit it next to the mounted one on the other side and you will see how the tread is the same.
Old Nov 25, 2009 | 04:30 PM
Steady's Avatar
DC2R
the drive shaft turns clock wise.it puts more weight on the right. this phenomenon happens regardless if you have lsd or not.
Ever see pictures of drag cars on launch and there always tweaked to one corner? same thing except they have pretty weak bodies.
Old Nov 25, 2009 | 07:55 PM
Dk1's Avatar
Dk1
Thanks for the info.
I am willing to pay up for the necessities of owning a car like this. I just needed to know WHY.
Thanks again.
