C63 Snow Usage...Anyone??
And yes, this is my first winter with C63 and I am pleasantly surprised how confident this monster is with 500 HP and RWD. Car looks like hell though
I know off topic
thanks
If you even hit a thin layer of snow or ice, the Perelli PZ's are the worst, most dangerous tires ever. The combination of the tread (or lack of), the immense torque, and no PP, the C63 was sliding all over. I was so freeked out because I went from dry ground to a thin snow patch ( and I mean like a thin dusting) and my antilock brakes went dead and the ESP was non-functional, all lights came on saying refer to user manual, as if the car was saying "Your fu**ed now. Good luck stopping. Just read the book as you slide into a wall"
Don't be stupid and think that you can even have the slighest control with this thing on ANY form of ice with the stock tires. Antilock brakes freeze and you are its b**ch until it stops.
This also happened to me pulling into a shell station, I was fishtailing and drifting all over. I almost hit the metal bars that surround the pump. I couldn't even get up the slight incline on my driveway into my garage, the wheels kept spinning. I had to pull back and catapult it in.
-if the roads are not plowed and there is greater than 3 inches of snow, the car performs quite poorly....ESP constantly flashing and difficult to travel faster than 60km/hr period
- I have had the ESP/ABS system temporarly fail (see previous threads) on 2 occasions so far........once from being "overworked" through 10-12in of snow and once on aggressive inclines and declines
-stuck going up my driveway twice......there was some ice below the snow.
-Overall I am a bit dissapointed in the "winter" performance of this car. I think that this is largely due to the fact that I was spoiled with an Audi RS4, and a VW Touareg before that. I did not expect the C63 to be on par with a 4x4 vehicle but I thought it would be better than it is. Our conditions can be quite bad sometimes because of high winds, lots of hills, and the fact that the roads are not always plowed.
-I absolutely love the performance of this car for 8 months out of the year and it is definitely a keeper. However, I will most likely buy a winter SUV next year.
-Just my 0.02
-Just my 0.02
If you've ever driven and spoiled by AWD and expect vehicles to perform that way in the winter, your only choice is an AWD car.
-Just my 0.02
We got a rediculous amount of snow, and have been driving the C63 fine everyday. Like SebringSilver, I'm using the Hankooks IceBears for winters. They're OK in the snow and ice, it's the cold dry performance that's awesome. They have really good dry grip for a winter tire.
I drive pretty much with ESP-Sport mode, all the time, and ESP-Off at nights. ESP sport gives enough wheelspin to get going a lot easier from a stop (ESP-On is TOO intrusive), and ESP-Off when nobody's around so I can drive like an @sshole.
Is this a factory paint job? I really want matte black on my car, and the dealer in Chicago is just saying that it isn't possible on the C63 at all.
but i'll bite. 255 will be ok since it is a winter tire. however in theory it is better to go more narrow for winter tires. most people will run 225 or 235 (i run 235 on all four corners). the reason to go more narrow is that it cuts through snow better than if it was wider
I'm thinking of getting a cheaper set of 18s on rims for the winter instead of running the stock 19s.
I've decided to go with 225s or 235s all around. I've tried checking a few local shops and ended up ordering a set from 1010tire, but they ended up canceling the order on me because they couldn't guarantee the wheel fitment due to the clearance on the amg brakes even though the measurements matched the recommended 18x8 45mm offsets.
Wondering if anyone has recommendations for some cheap 18in wheels just to use in the winter?
I'm thinking about ordering these instead now in 18x8 +45, but again not totally sure about the fitment
http://www.rtxwheels.com/en/content/turbine-3
Any thoughts or suggestions appreciated. Anyone have issues fitting wheels over the brakes even with the right offsets?
