C63 AMG (W204) 2008 - 2015
Aftermarket wheel Thread.
Old Sep 20, 2015 | 10:51 PM
  #2176
Phil Chow's Avatar
W204 C63
Originally Posted by Roswell
At +52mm, u don't need to shave 3mm to make them +55mm. U should clear no problem as is.
Fair enough. Guess I can always just bolt them on and see. The only thing is, I'm afraid of ordering the tires (275/30/19 Michelin PSS), and then throwing the wheels on, and then having them rub. Is there any camber adjustment in the rear? From what I can gather, it's literally like down to a few MM which either rubs, or doesn't rub.
I plan on being relatively low? Essentially no wheel gap, something like this:
This is a 19x8.5 +45 / 19x10 +50 on 235/35/19 & 265/30/19 Michelin PSS setup, and he didn't rub. That's why I was thinking I might need to take it to a +55, to help offset that extra 10MM in tire-width.
Originally Posted by Mort
It is difficult to pin it down exactly when you are running tolerances this tight. I am running 19 x 10 ET +52 with MPSS 265/30/19 on my 2012 with KWV3 lowered all the way (~.75") and it rubs the fender joiner every now and then. Just a snick but a rub all the same and no rear passengers. I ran the same wheels on my 2010 lowered on H&R springs (~.75") and was able to run MPSS 275/30/19. I think you should be OK on the inner fender at ET+55. Keep an eye on the lines running to the fuel tank as they protrude the most into the inner fender area (right rear ahead of the axle).
Any photos of your car? The V3s only go down 0.75" all the way down? Weird how you rubbed with the 265s, but not on the 275s.
Mort, I find it strange that u can run the same wheels with 275 on ur pre-FL car no problem.. But u get slight rubbing with the same wheels on 265 with ur FL car.
Ride height & stiffness must play a role.
Does the Pre-FL have more "room"? I remember reading somebody said that it did? And the coupe vs sedan is slightly different too?
Old Sep 20, 2015 | 11:35 PM
  #2177
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I'm not sure if pre-FL & FL are different, but regardless I still believe shaving 3mm off ur wheels is not the safest solution. If u are worry about rubbing, I would go 265 instead of 275.
Old Sep 21, 2015 | 04:51 AM
  #2178
pNutz's Avatar
2008 Mercedes C63
Got me a new set of wheels for the track. It was a pain to make it work but in the end, it was all worth it.
17" Weld Racing Rt-S S77 wheels wrapped in 255/40 Toyo R888
Old Sep 21, 2015 | 09:43 AM
  #2179
Kriston's Avatar
C63 AMG
LOVE the setup, the 17's with the Chunky R888's look bad ***. Well done sir!
Old Sep 21, 2015 | 07:19 PM
  #2180
oliver@velosdesignwerks.com's Avatar
Former Vendor of MBWorld
AMG
Velos VII Forged Wheels
Old Sep 22, 2015 | 12:16 PM
  #2181
Mort's Avatar
Meng, I find it a little strange as well. There are some differences that may account for it. The spring rates in the KWV3 may be different from the H&R lowering springs and the KW shock rates set differently from the OEM shocks. The ride height is close to the same but measured on different cars so it may not be exact. The KW says a max. drop of 1.2" on the rear but I only got a measured drop of 7/8" lowered as far as possible. The camber is similar at ~ -2.1*. It is just that what works on one car may not hold true for a different car when everything is set so close to the limits.
Old Sep 22, 2015 | 12:59 PM
  #2182
JeffDL's Avatar
C63
my preFL sedan was very different from my now FL coupe. I was able to run wider wheels and tires with more aggressive offsets on the preFL sedan than the FL couple.
example preFL sedan ran:
19x8.5 et35 with 245/35/19
19x10 et 55 with 275/30/19
never ever rubbed over anything.
FL coupe runs:
19x8.5 et40 with 245/35/19
19x9.5 et45 with 265/30/19
rubs over everything. the front much more so than the rear. My front tires come in contact with the fenders over almost every bump. I've done a lot of work to the fenders and it's much better but it will still rub.
both cars were on H&R springs and both cars ran the same Hankook tires.
Old Sep 22, 2015 | 11:43 PM
  #2183
Roswell's Avatar
^^ interesting Jeff, my pre- FL runs 19x9 +40 with 245/35 no problem. Ur 19x8.5 +40 is less aggressive.
Old Sep 23, 2015 | 10:23 AM
  #2184
Phil Chow's Avatar
W204 C63
So, I guess we can conclude that the FL Coupe cannot run as aggressive as the PreFL Sedan?
Old Sep 23, 2015 | 08:21 PM
  #2185
Jiew's Avatar
09c63
HOLY that looks so hardcore!
Old Sep 23, 2015 | 10:56 PM
  #2186
Durban's Avatar
C63, S55, 190E 16V, S600 Maybach, S550, GL550
ADV.1 15 MV2 SL
Old Sep 28, 2015 | 01:18 AM
  #2187
HTX C63's Avatar
2009 c63
#BECAUSEBAGS
Will post more pictures once the build is done.
Old Sep 28, 2015 | 01:20 AM
  #2188
HTX C63's Avatar
2009 c63
Originally Posted by Durban
ADV.1 15 MV2 SL
Love those Adv15's! They look great on our cars in any configuration.
Old Sep 28, 2015 | 11:02 AM
  #2189
Durban's Avatar
Couldnt agree more
Old Oct 4, 2015 | 10:23 PM
  #2190
Mr. Lin's Avatar
2008 C63
anyone ever run into caliper clearance issues on stock brakes? coming from an sti, we had to pay special attention to spoke design or run the risk of the wheel not fitting over the caliper. it seems there is no shortage of wheel options for these cars, and the only limiting factor seems to be offset, tire size, fender rubbing, and some combination of the three. is that the case?
Old Oct 5, 2015 | 07:13 AM
  #2191
Roswell's Avatar
^^ spoke design is definitely a factor on our cars as well, some style like Vossen deep concave would not clear our BBK. Unfortunately our cars can't take much concavity.
Old Oct 5, 2015 | 08:09 AM
  #2192
Mr. Lin's Avatar
2008 C63
and from what I've read, it's not wise or feasible to roll the fenders? is this also correct? the offsets of most wheels that have been posted seem so arbitrary. maybe everyone in the subie world just all ran the same sizes 18x9.5 +30/35/38 lol
Old Oct 5, 2015 | 08:59 AM
  #2193
RNS-11Z's Avatar
09 C63
HRE 20x9 and 20x10
Old Oct 5, 2015 | 09:57 AM
  #2194
JeffDL's Avatar
C63
i rolled, cut, and worked a grinder on my fronts. the rears are 2 pieces so if you try to roll they will probably split apart.
Old Oct 7, 2015 | 01:23 PM
  #2195
Roswell's Avatar
^^ u are a brave man bro lol
Old Oct 7, 2015 | 01:38 PM
  #2196
Julie@KonceptCars's Avatar
MBZ
pNUTZ your R888s look amazing on that setup. I'm sure they perform well at the track. Very aggressive!
Old Oct 7, 2015 | 03:20 PM
  #2197
Kriston's Avatar
C63 AMG
I'm building a new square setup as we speak. 18 x 9.5 ET 45 All around. They are flush
Old Oct 7, 2015 | 03:24 PM
  #2198
HTX C63's Avatar
2009 c63
And.. shes on air. Heres a crapy cellphone pic.
Still not 100% satisfied with the front fitment. plan on going down to a 225/30 up front to lay the car out evenly when its aired out. will post more pictures soon
Old Oct 7, 2015 | 03:28 PM
  #2199
HTX C63's Avatar
2009 c63
you can definitely roll the rears it does take some grinding. I actually pulled my fenders instead of rolling them, and I just used a heat gun and some pressure to line up the rear bumper with the curve of the fender. Just be careful not to heat the bumper up too much, or youll melt it lol
Old Oct 8, 2015 | 10:37 AM
  #2200
Mr. Lin's Avatar
2008 C63
so the process is not as simply as just heating the arch and bolting up a roller and going to town? what exactly needs to be grinded and are you just taking a dremel with a grinding wheel to it? this is a new concept to me.
