Aftermarket wheel Thread.
#2302
My HRE's offset are 50mm rear and 41mm front...recommended by HRE so I would think your would be fine. My wheels are 19x8.5 front and 19x9.5 rear
#2303
Ok I am one step away from confirming my order on Niche M130 wheels 19x9.5 with a 50mm offset for rear and 19x8.5 with a 42mm offset for the front. Is this not a safe set of offsets for a 2012 C63 sedan P31? The guy I am ordering from is telling me he things the 42mm offset might not be good. I just want to know what the offsets I need to order are so I can get these wheels in asap.
#2304
My first set was also recommended by HRE & same specs as u. I was disappointed with the 19x8.5 +41.. I now have 19x9 +40 & 19x10 +50.. Perfectly flush.
#2305
ENVē (03-07-2016)
#2307
HRE P40SC GLOSS BLACK FOR SALE !!
Hey guys i have great condition HRE P40SC WHEELS came off my 2012 C63 AMG ,
8.5 by 20 and 10 by 20,
bought for close to $8k selling for a resonable deal with the tires on , Location is California and ill let them go at $4,400.
Message me if interested for pics and etc ... also to set up a time to check them out in person if local or could be done over the phone,
Thank you !
Sam.
Thank you !
Sam.
#2308
Nope perfect fit for mine, also have KW v3 so idk , i also put it on an E63 amg 2011 just to see fitment and it was perfect.
#2310
[QUOTE=tglems;6730492]Thanks! Rims are a ways down on my mod list...but they are on there so I like to have a good idea about what I'll aim at!
Thanks for your reply btw it wasnt until i replied to you that i realized you were talking to OP Roswell haha, ohh well you got some info off of me too , and yeah just before buying anything double check about the rubbing ofcourse, i broke my 09 c63 fenders putting some other type of wheels rather not mention the name , but yeah it was a bummer !
#2312
Looking for a C63AMG
Hello, Im about to get a C63 and I want to get aftermarket rims. Ive read that the perfect measurement in the front is 9x19 ET 40. Unfortunately the rims I want I can only get in 9.5 ET45, which is pretty much the same on the outside. But what I am worried about is the inside, does anyone know if there is still clearance to the suspension? Im planning to get a KW V3.
#2316
I'm pretty sure 9.5 +45 will run the inner suspension especially lowered on KW's. But who knows, maybe stretching a 235 will clear.
#2317
The widest wheel I've seen on a C63 W204 front is 9.5j +25 (245/35) with -3 degrees of camber or whatever stock maxes out to.
When playing around with sizing, it's good to have a pair of 5mm and 10mm spacers to play around with clearance.
Physically I am thinking 9.5 +35 is the perfect size and offset for super aggressive front fitment without spacers, clearing the caliper... but it all depends on the wheel design/face and how low you are, tire brand / size etc.
#2318
Also Im ordering tires. Michelin PSS. Can I go 275 width in rear on stock height without rubbing (might lower later) or should I do 265 and stay safe? I hear the PSS run wider track then other tires.
Also what are the actual sizes of the tires I should be ordering as far as profile? I heard the front needs to be different than the rear i.e. 35 vs 30 etc.
Thanks guys! You have been a great help to me. I ordered the TPMS sensors on ebay and hoping they function well.
#2319
2014 C63 AMG 507 sedan
So I am good at an 8.5 inch width front wheel with +42 to clear everything correct?
#2321
hey guys,
I'm looking to get the 20" Avant Garde M310 for my '13 c63
The seller is saying:
20 X 8.5" fronts & 20 X 10" rears
Offset: 32 mm fronts & 35 mm rears
Would this work or would I really be stretching it?
#2324
Ok I am not sure what is going on but this is the third time they got back to me saying the +42 fronts for the Niche M130 wont clear the brake caliper on my P31 car.. I am not understanding why they continue to give me push back.
Anyone here have Niche M130 and have experience with this? I need to get this confirmed as I already ordered tires and TPMS sensors for this.
It is really frustrating going through this.
#2325
^^ post pics of the wheels, maybe the design is too concave for our fronts? Technically, 19x8.5 +42 should clear no problem.
