tire pressure
2010 Mercedes Benz C63 AMG, 2011 BMW X5///M
tire pressure
my dash says to correct tire pressure . . . . it shows 36 on the front tires and 36 on the rear left tire and 35 on the rear right tire
is this normal??
is this normal??
C63AMG
You can adjust the reading which you consider nominal via the instrument panel settings pages.
I have ours set for 40 psi on all four corners. Am running one size up from stocks as of last month when we did the first tire change since new (6000 miles).
On the driver's door-post placard, 41/45 psi for front/rear stock tires, however, per the owner's manual, on the fuel filler door, another placard additionally listing 39 psi on all four tires.
We have the performance package with 18 inch rims.
yo dawg, the tire pressure system warning you be getting is wrong mang, what you need to do is fill the whole car and tire with air to 900psi to equalize the awesomeness you be getting for a first car c63 mang
shiet we be partaying up all naight long and pounding the bestest pussay in and outa town dawg
2007 SRT8 Charger, 09' C63
1 Post
2011 GLK350, 2010 ML350, 2008 C63 AMG
do you know what your baseline setting was? If it was 39 psi from the beginning then there is a chance that the tire pressure is off. I would recommend increasing the tire pressure to 39 psi and then reset the system.
C63
I've found my +pp car to be very sensitive about tire pressure. My door sticker has 41 psi front and 45 on the back. my light will only go out with those pressures
PP 272-273 C-Class Operator's Manual tells you how to reset the TPMS for the new tire pressures you have chosen. Those pressures will then be normative.
