C63 AMG (W204) 2008 - 2015
Old Jun 9, 2015, 03:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Hardwired Escort 9500i Radar Detector :: Photos
Old May 20, 2010 | 08:38 PM
  #51
longbow0404's Avatar
2019 E63s
clean. super clean
Old May 20, 2010 | 10:38 PM
  #52
andrusha's Avatar
C250 12 / CLK63 BS / ML63 09 / GTR 2012
Originally Posted by Newzchspy
I have two V-1, two 9500iXs and one Redline. I am a frequent poster on RD.net and first let me say, Nice install. Big problem, however is that you'll get no rear LIDAR coverage nor front due to the HIGH placement of the unit. Lidar hits are on the front /bottom of the car, usually from the Front plate out or the headlights in, wherever they can get a "fix." To the rear, its usually the rear plate since thats always on a car and an easy target. They will also go for the tailights as well. Usually Lidar hits are ticket "notifiers" anyway, so it may be moot. (unless you're using LI countermeasures and Veil Coating as well). Radar tends to travel high, so your're in the best position for that. LIDAR and you're toast. It'll probably be OK for radar BUT not good at all for Lidar!
So let me ask you is it bad idea to put Passport that high?
Should I lower mine?
Old May 21, 2010 | 12:55 AM
  #53
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Mount as high as possible for best radar detection. Countless posts about this topic can be found over at radardetector.net. If you are serious about learning more, join that forum and spend some time researching.
As far as laser, it does not matter on a window mount detector. If your detector does happen to pick up a laser signal and you are traveling above the posted speed limit, you are going to get a ticket. Invest in a laser jammer if you want laser protection.
Old May 21, 2010 | 07:50 AM
  #54
andrusha's Avatar
Thank you so much. Will join that website.
Old Nov 11, 2010 | 12:45 AM
  #55
andy_c63's Avatar
2009 C63 AMG
I got my first ticket in 4 years on the 2nd day after I got my C63.
Now I am getting Escort Passport 9500ix and will probably do the same install, but on the left side. I figured this way it will be easier to reach and the rear laser port will be less obstructed.
Old Nov 11, 2010 | 12:52 AM
  #56
Sincity's Avatar
Forget about the laser port. By the time it goes off, you are toast.
Old Nov 11, 2010 | 01:16 AM
  #57
andy_c63's Avatar
2009 C63 AMG
Well it might still make some sense... what if I am going 100 and accelerating? If I see a laser hit, I will sure slow down. But if I don't, then I will keep going faster and the consequences likely will be much worse.
Old Jul 30, 2012 | 04:48 PM
  #58
RSF C63's Avatar
(My car); 2012 vw golf TDI manual. (dads car) 2011 C63 Amg. P31. Carbon trim.LSD.
well depending where you are, if your going 100+ your license is gone anyway. If you get a laser hit your toast. forget about the lidar port. place it for the radar.
Old Jul 31, 2012 | 11:27 AM
  #59
georgieff's Avatar
2010 C300
Thanks for the guide!
